The HA device (raspberry pi 3) is on the same layer 2 network as the IP interface.
I have used the guide for installing the Home Assistant Operating System for the raspberry pi.
Alright, thank you very much!
I have found a bug in our logic thanks to your logs . It handles the response wrongly when the order of description information in the frame is not as expected.
I’ll try to put up a fix tonight or so. This will be resolved in the next version of xknx (and HA).
I’m planning to switch to KNX secure using the Weinzierl IP Interface 731. Has anyone have an experience with secure using that device? Other than that, from what I figured, KNX secure is used during comissioning through ETS but also during use over TP as well as IPNet. Those devices that cannot speak secure will use normal KNX. Is that right?
I have been trying to get HA to connect using IP secure but authentication is failing.
Did you have to create the knx directory to put the .knxkeys file into?
I then tried to load a TCP only tunnel connection and all my entities lost their custom icons etc.
Will this be the case when I get the IP secure working?
I’ve restored to a backup for now but thought I would check before going too much further.
