KNX Select Exposure
Connect a Home Assistant Select or Input Select to a knx decimal value
The selected Entity will be exposed to the knx bus. Read requests will be processed on the state address and to change the value of the select, you can send a write telegram to the select address. The adresses should use DPT 5.005 and the index of the select will be used to set the value. No further translation will be done.
blueprint:
description: "# \U0001F3E0 KNX Select Exposure\nConnect a Home Assistant Select or Input Select to a knx decimal value\n
of the select will be used to set the value. No further translation will be done."
author: richardpolzer
domain: automation
input:
select_entity:
description: >
Select to publish to KNX
selector:
entity:
filter:
domain:
- select
- input_select
select_address:
name: Select group address
description: >
Group address for the select. DPT 5.005
Example: '1/0/1'
select_state_address:
name: Select state group address
description: >
Group address for publishing the state to. DPT 5.005
Example: '1/0/1' (leave empty if unused)
default: ""
mode: parallel
max_exceeded: silent
variables:
select_entity: !input select_entity
select_address: !input select_address
select_state_address: !input select_state_address
- platform: homeassistant
event: start
- platform: event
event_type: automation_reloaded
- platform: event
event_type: event_knx_reloaded
- platform: event
event_type: service_registered
event_data:
domain: knx
service: event_register
- platform: event
event_type: knx_event
event_data:
destination: !input select_address
telegramtype: GroupValueWrite
direction: Incoming
- platform: event
event_data:
destination: !input select_state_address
telegramtype: GroupValueRead
direction: Incoming
- platform: state
entity_id:
- !input select_entity
- choose:
- conditions:
- condition: trigger
sequence:
- if:
- condition: template
value_template: "{{ select_address != '' }}"
then:
- service: knx.event_register
address: "{{ select_address }}"
type: decimal_factor
- if:
value_template: "{{ select_state_address != '' }}"
then:
address: "{{ select_state_address }}"
- conditions:
sequence:
# change the input select here HA
- service: "{{select_entity.split('.')[0]}}.select_option"
entity_id: !input select_entity
option: "{{ state_attr(select_entity,'options')[trigger.event.data.value | int(default=0)] }}"
- conditions:
- condition: or
conditions:
sequence:
#report the current value here
- service: knx.send
payload: "{{state_attr(select_entity,'options').index(states(select_entity))}}"
response: "{{trigger.id == 'select_state_address'}}"
