Oh dear, what is that Anydesk thing and why doesn’t it allow to make screenshots? It’s really no pleasure to look at monitor photos 😵💫
Anyway…
IA is the address the tunnel is assigned to (ie 1.0.3). Yours seems to be 0.0.1 if the telegram in the first photo is the GroupValueRead (the column is too small to see it) from HA.
Depending on your topology, but my first guess is that should be something like 1.0.x or 1.1.x. You can set this somewhere in the interfaces settings (or web view depending on interface model).
In the 2nd photo you can see your 7/2/22 has no assignments - so it is an empty GA. If you open 7/2/22 you’d see it has no content. Connect it to a group object…
In your original post you also has 7/2/22… so maybe just a typo?!
Every device should be in the same line (eg 1.1.x like Your Switch actuator) if you don’t have any line couplers or routers. I’d change the individual addresses accordingly.
(Except if this touch panel thing is an ip device , not a TP device - but you would have a router then…)
HAs IA is not shown here. You can see it in the diagnostics file or in ETS Monitor when it sends things.
yes it was a type, but in the YAML file, so I changed it to 7/2/2 and it worked.
Thks for your quick support, how embarassing that I have used last several days, looking for this error and reading god knows how much, and then it was a simple typo.
