I’m using an analog output (0-10V) from MDT (https://www.mdt.de/EN_Analog_IO.html) to control the air ventilation. I would like to integrate this into my Home Assistant, but I don’t understand how. I know that I could define a sensor to get the current value (state_address) of the analog output, but which type of integration will allow me to set the value (percent) of the output?
It would be nice to have one object that will keep everything aligned, because right now when I change the value on the KNX bus only the sensor will get the new value and the input_number will still show the old value. I’ve tried to keep them in sync with an automation but failed misserably.
@farmio: this is what you meant with the template object, right?
