Has anyone else seen that KNX status (e.g. lights and HVAC controller) messages are not updating following server reboot? Was OK on 0.117.4 and before. (viewed from Lovelace).
yes same here since updated to 0.118.0, KNX Switch status are not showing up.
Working with my light
same hereā¦ Will check the .1 and .2 release. Just checked with 0.118.2 but the same issue. NO KNX switch satte sync after restart
Itās a known problem for switch, cover position and climate mode.
Lights should properly initialize!?
Matthias, I donāt quite understand, is this a new 0.118 issue? Iāve not see this issue for two years now, 0.117 was fine. It appears that after restart the status is not queried. I do have a big KNX system in my house.
PS: I do wish we could sort out the thermostats (KNX operating modes) in Lovelace. Itās used to be so good.
Same hear 0.118.2 is the same.
I stopped searching and have reverted to 0.117.6 where everything is just fine.
Am going to keep watching the updates and the changes to the xknx.
I confirm that I have the same issue with 118 (all subversion). I also have some problem with brightness value update (I start some light, but the brightness value stay at 0).
Maybe the problem is due to the fact that I split my command and status group (which is needed is some circumstance).
Till 117, everything was working fine, but with 118, itās not working.
ex of a knx switch
- name: 'outlet living room'
address: '2/0/1'
state_address: '4/0/4'
anybody can help ?
Fred.
Fred, I have split command and status groups, but in the same yaml sub-file and Iāve not seen this, but I do have the status update intervals set to about 5 minutes and on status change on the sensors. (Gira TS3/Plus in most cases). Example below:
- name: 'Lounge Downlights'
address: '2/3/4'
brightness_address: '2/5/4'
state_address: '0/4/4'
brightness_state_address: '0/2/4'
My knx is set to only send status on change. If I do a āmanualā read status with ETS, the value is well updated in HAss. So, the main problem is at boot.
Can also be a problem with the management of the KNX queueā¦
Yes, agree the problem is on boot since 0.118.x no status information is queried from any sensor. The key line that not working is the āstate_updater: trueā which according to the documentation:
state_updater boolean (optional, default: true)
The integration will collect the current state of each configured device from the KNX bus to display it correctly within Home Assistant. Set this option to False to prevent this behavior.
It worked prior to .118.x
configuration.yaml
knx:
tunneling:
host: '192.168.0.254'
port: 3671
local_ip: '192.168.0.24'
state_updater: true
switch: !include knx_switch.yaml
light: !include knx_light.yaml
sensor: !include knx_sensor.yaml
scene: !include knx_scene.yaml
climate: !include knx_climate.yaml
binary_sensor: !include knx_binary_sensor.yaml
Another pull request that might resolve this: https://github.com/home-assistant/core/pull/43645
Letās hope we can get this in 0.118.4 or 0.118.5 or something
Yes, I hope, I cannot revert to 117 due to other bugsā¦
I did revert, but as I had not taken a backup of my data before updating, the db is now in a mixed state, breaking some other integrations.
seems 2020.12 has fixed it for me
I am using two very similar actuators.
For the ABB SA/S8.16.2.1the status is updated after reboot. For the ABB SA/S8.16.6.1 with as far as I can see identical configuration it is not updated after reboot. Does anybody have an idea where this comes from?
Missing read flag in ETS.
I wonder why you post this in a 1 year old thread
ItĀ“s maybe still the same problem.
The read flag in the ETS was there. I do not know why but now it is working again after I reprogrammed the actuator.
No it is not working again. Using the ETS monitor I found out that the ABB ABB SA/S8.16.6.1 reports incorrect states. So oviously a problem of the ABB SA/S8.16.6.1 firmware.
