I’m pretty new to HA and startet to connect it with my existing KNX-installation to realize a visualization.
Mostly anything is now connected, but when I try to readout the actual time from the bus, it shows an error:
Invalid config for [knx]: [time] is an invalid option for [knx]. Check: knx->knx->time. (See /config/configuration.yaml, line 15).
For knx in 2023.8 (if anyone finds this thread in the future)
Note that currently the VSCode plugin isn’t updated yet, so if you use this, it will show an error. You can safely ignore that and use HAs config validation in “Developer Tools”
