I have HA setup and can communicate with my KNX Bus via HA. I have a few lights, scenes, and shutters configured and it all works as expected. I have the time exposed in my HA knx configuration but it never gets sent to the bus and I don’t see any attempt in the HA knx debug log either. I have MDT Glass Push Buttons II Smart controllers in each room and I can send the time to all of them from ETS, but they all drift eventually and I want them to be automatically updated.
Thanks for the reply, but no change with datetime DPT. I also have a few automatons that seem to be running just fine to toggle things like the Day/Night switch on the bus. I don’t see any debug log entries with the time GA, so I really don’t even know where to start looking.
I have just tried it and it works on my machine. Some seconds after starting HA I found 2020-01-11 11:07:50 DEBUG (MainThread) [xknx.telegram] <Telegram group_address="GroupAddress("0/6/10")", payload="<DPTArray value="[0xcb,0x7,0x32]" />" telegramtype="TelegramType.GROUP_WRITE" direction="TelegramDirection.OUTGOING" />
in my logs.
This was my test configuration. I used the xknx custom component but that should be on the same state as current knx component but for some reason the normal wouldn’t load on my dev machine.
Yeah I just noticed that the knx interface discovery process was running at startup even though I had the interface defined in my xknx.yaml config. I moved my knx settings described above to configuration.yaml and time was successfully published after a restart. So I guess my problem is with the path to my xknx.yaml file, which is in the config directory. I get this message at startup
You didn’t mention you were using xknx.yaml configuration file. This needs completely different syntax.
I’m not sure devices (time exposure is a device itself for xknx) can be configured on both places simultaniously.
Yeah I was under the impression that worked like the other external files for lights, switches, etc. I am just getting started with HA, so I apologize for the wasted time.
Since you said the syntax is different for the external file, does that mean it uses the syntax from https://xknx.io/?
Yes exactly. You can use the integration from external files like lights.yaml that are included in the configuraiton.yaml. Its just the file you define in the knx: config_file parameter that is treated differently. This is forwarded to the integrations knx implementation that is xknx which has a different syntax for stand alone usage.
