Hi all,
getting this error with knx gw 731. ETS is running fine with it.
Here my ha config:
knx:
tunneling:
host: ‘192.168.2.xx’ #knx gw
port: 3671
local_ip: ‘192.168.2.xx’ #server ip
Can you help?
Thx in advance.
le “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 190, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File “/usr/lib/python3.6/site-packages/homeassistant/components/knx.py”, line 80, in async_setup
yield from hass.data[DATA_KNX].start()
File “/usr/lib/python3.6/site-packages/homeassistant/components/knx.py”, line 140, in start
connection_config=connection_config)
File “/usr/lib/python3.6/site-packages/xknx/xknx.py”, line 66, in start
yield from self.knxip_interface.start()
File “/usr/lib/python3.6/site-packages/xknx/io/knxip_interface.py”, line 76, in start
self.connection_config.gateway_port)
File “/usr/lib/python3.6/site-packages/xknx/io/knxip_interface.py”, line 106, in start_tunnelling
yield from self.interface.start()
File “/usr/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 73, in start
yield from self.connect_udp()
File “/usr/lib/python3.6/site-packages/xknx/io/tunnel.py”, line 79, in connect_udp
yield from self.udp_client.connect()
File “/usr/lib/python3.6/site-packages/xknx/io/udp_client.py”, line 167, in connect
remote_addr=self.remote_addr)
File “uvloop/loop.pyx”, line 2673, in create_datagram_endpoint
File “uvloop/loop.pyx”, line 2658, in uvloop.loop.Loop.create_datagram_endpoint
OSError: [Errno 99] Address not available
