after update of KNXD from 4.4.2 to 4.4.4 my configuration does not work any longer. When I try to save a configuration I get the following error.
Fehler beim Speichern der Add-on-Konfiguration, expected int. Got {'address': '0.0.1', 'client_address': '0.0.2:8', 'interface': 'usb', 'device': '/dev/bus/usb/001/001', 'log_error_level': 'warning', 'usb_filters': 'single', 'ip_address': '', 'dest_port': '', 'custom_config': ''}
The following error I get when I try to start KNXD
expected int.
All was running fine with KNXD 4.4.2.
I am using:
- Core Version core-2022.4.3
- Supervisor Version supervisor-2022.04.0
- Home Assistant OS 7.6
