Kwikset 916 Zwave+ Access Control Information
The alarm_level and alarm_type codes are readily available in the forums for the Kwikset 916 (non zwave+) models. Has anyone figured out the access_control codes for the Kwikset 916 zwave plus model? Not sure if it matters or not, but I am looking for codes related to the OZW Beta integration.
Thanks in advance!!!
They should be the same.
Are you sure? Several differences. Like the Zwave plus model has an entity for replace battery now and soon where as the zwave model has codes for low, critical and too low to operate. Also, many of the acces_control codes are different. The zwave plus model uses 1-6 and 11 whereas not the case with the zwave model.
Access Control and Alarm Type are different types of notices, so the values will be different. One is v1 and one is like v4 (I don’t fully recall).
Sorry, maybe I worded my question incorrectly. I guess what I am looking for then is the access_control values so I can set up automations similar to the ones I had for Alarm Type with my non zwave+ models.
I was able to pull it from the SDS XML from SiLabs, here’s your codes:
Friendly Name Hex Value Number
Manual lock operation 0x01 1
Manual unlock operation 0x02 2
RF lock operation 0x03 3
RF unlock operation 0x04 4
Keypad lock operation 0x05 5
Keypad unlock operation 0x06 6
Manual not fully locked operation 0x07 7
RF not fully locked operation 0x08 8
Auto lock locked operation 0x09 9
Auto lock not fully locked operation 0x0A 10
Lock jammed 0x0B 11
All user codes deleted 0x0C 12
Single user code deleted 0x0D 13
New user code added 0x0E 14
New user code not added due to duplicate code 0x0F 15
Keypad temporary disabled 0x10 16
Keypad busy 0x11 17
New program code entered : unique code for lock configuration 0x12 18
Manually enter user access code exceeds code limit 0x13 19
Unlock by RF with invalid user code 0x14 20
Locked by RF with invalid user code 0x15 21
you da man @firstof9, thank you!!!
How would you go about finding these codes for a Kwikset 914 Z-Wave lock? I have both a 916 and 914 so this is awesome mind you :slight_smile:
They’re all the same if you’re lock is newer.
But the 914 doesn’t have usercodes; it’s just a deadbolt.
Does your lock have Access Control sensor or Alarm Type sensor?
Alarm Type I believe.
These are the only codes I’m aware of for locks and the alarm_type sensor.
Code Status
0 No Status Reported
9 Lock Jammed
17 Keypad Lock Jammed
18 Keypad Lock
19 Keypad Unlock
21 Manual Lock
22 Manual Unlock
23 RF Lock Jammed
24 RF Lock
25 RF Unlock
26 Auto Lock Jammed
27 Auto Lock
32 All Codes Deleted
33 Code Deleted
112 Code Changed
113 Duplicate Code
161 Bad Code Entered
162 Lock Code Attempt Outside of Schedule
167 Battery Low
168 Battery Critical
169 Battery Too Low To Operate Lock
This is great! Thanks so much :smiley:
