Label or indicator to automation off identify
Add label or indicator to automation off identify
So looking at this, I’m not sure exactly what you are asking for.
I am also not clear about:
  • This Device is working or not
  • The ‘issue’ you are correcting is in the Device where it reports features.
  • The issue is in Home Assistant’ integration
  • What you want it to look like in the end.
Anyone that could help you fix the problem would need to know these things as well.
More about Feature Requests.
I could have sworn that section used to read: “The device is part of the following automations”.
You can still see this if you go to device settings > related as per below
Then again, I fail to see the value in this FR.
If you want to see whether the actual automation linked to this device is enabled, just go to Settings > Automations and check there. Remember that an automation can be tied to multiple devices (and services, as well as entities without any device).
If you what to see whether the actual automation linked to this device is running, then that will only be true for a millisecond, unless you have some kind of (long) delay going on.
