Hi!! I cannot add to a lateral bar, with this code, one thing or another.
I put this code:
panel_custom:
url_path: config/server_control # url_path Necesita ser única para cada configuración de panel_custom
sidebar_title: Server Controls
sidebar_icon: mdi:server # https://materialdesignicons.com/
module_url: /local/panel-redirect.js # ‘local’ is ‘/config/www/’
url_path: redirect-supervisor # url_path Necesita ser única para cada configuración de panel_custom
sidebar_title: Supervisor
sidebar_icon: mdi:home-assistant # https://materialdesignicons.com/
config:
target: /hassio/dashboard # Hacia dónde quieres redirigir
But no works the shop, to put addons and the file editor, I can’t install and i don’t know how to do.
Thanks in advance!
The Shop of addons to add file editor and more addons. The button of the code, shows dashboard, no the Shop. I dont know if I’m explain certainly. I have an installation in synology nas by docker, and yes, I tried to refresh ctrl+f5 in the browser and to reboot the server
Nothing mate, I don’t know what happen but it doesn’t work. What more can I do?? Now, Resumen (First section, and addons, now are empty, and dont shows the store) Thanks in advance!
The thing must be easy but I don’t understand it and I’m starting to despair. Could someone connect remotely to help me? I don’t understand the link and why things don’t work for me.
I can’t found the form to do that. I’m having problems with the ports too, because it puts in 8123 for default, and when i try to access, the browser say that is not secure in the lock icon, and with plex with 32400 the same but the certificates are correctly installed. So it’ll be a pleasure to me, if you want to met or check my installation via teamviewer or similar and discord to can speak.
