Latest Supervisor wont start
Hey
Does anyone know what they latest version of supervisor wont start in my case?
Does anyone know how I restore if I can get to the restore/backup menu?
Here is my log
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[15:23:33] INFO: Setup udev backend inside container
[15:23:33] INFO: Update udev information
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[15:23:33] INFO: Starting local supervisor watchdog...
22-07-06 15:23:36 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extraction
22-07-06 15:23:36 INFO (MainThread) [__main__] Initializing Supervisor setup
  File "/usr/local/lib/python3.9/runpy.py", line 197, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/local/lib/python3.9/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/usr/src/supervisor/supervisor/__main__.py", line 41, in
    coresys = loop.run_until_complete(bootstrap.initialize_coresys())
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 647, in run_until_complete
    return future.result()
  File "/usr/src/supervisor/supervisor/bootstrap.py", line 63, in initialize_coresys
    coresys = CoreSys()
  File "/usr/src/supervisor/supervisor/coresys.py", line 66, in __init__
    self._docker: DockerAPI = DockerAPI()
  File "/usr/src/supervisor/supervisor/docker/__init__.py", line 106, in __init__
    self._info: DockerInfo = DockerInfo.new(self.docker.info())
  File "/usr/src/supervisor/supervisor/docker/__init__.py", line 62, in new
    data["CgroupVersion"],
KeyError: 'CgroupVersion'
22-07-06 15:23:36 ERROR (MainThread) [asyncio] Unclosed client session
client_session:
[15:23:36] WARNING: Halt Supervisor
s6-rc: info: service legacy-services: stopping
[15:23:36] INFO: Supervisor restart after closing
[15:23:36] INFO: Watchdog restart after closing
s6-svwait: fatal: supervisor died
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info:
I have exactly the same issue since a few hours, watchdog is starting over and over again, but the Supervisor crashs.
Does anybody have a clue?
glad to know I am not on my own!
Exactly the same here
I got mine to start finally, but there have been a lot of issues.
First I have gotten a lot of restarts due to errors with max pending websocket requests, which is probably what you see now.
I am now up and running, but the system is now marked as unsupported and when I looked through the logs I found a line checking the site starting with https://version, but the update should have changed that to https://checkonline, so I am not even certain I am on the new supervisor version anymore.
Same issue here… Unfortunately I restarted my host so everything is down at the moment.
I have the same issue, everything is down, and supervisor is not able to start up.
Same for me (docker, Ubuntu)
Experienced the same issue today, I restored last backup and it fixed the issue
I have HA on a virtual machine on Proxmox, so for me it has been “quite easy” to restore a backup accessing the console.
I can access SSH… any tips on restoring?
I have the same problem. During a few months, the HA worked very well. Today supervision has been down. Any idea how to up it?
Well from the console using the command:
ha backups
you get the list of backups present on your machine (hoping you did a recent backup…), find the one just before the upgrade. and take note of the slug (i.e. something like slug: bf824b61)
execute the restore using:
ha backups restore <thenumberofslug>
sit and wait…
after the restore, I had full access to my ha
ah thanks… sadly… that method requires supervisor to be functioning:
Get "http://supervisor/backups": dial tcp 172.30.32.2:80: connect: no route to host
I wonder is there a manual way to do it
my bad, before upgrading Superviser, I updated SSH add-on
I have no password in settings, only authorized_keys2022-07-06 19_13_37-Window
What version of HAOS are you running? Or if you are not running HAOS then what is your host operating system?
im running Ubuntu 20
with Hass Supervised in Docker
Ubuntu, docker
docker container ls -a shows that the supervisor has got recently updated, about 1 hour ago, I did not trigger the update, and now the system is broken, anyone knows how to restore a previous version of the docker image that works, and prevent auto update? I do not remember updating supervisor manually, so it must have been done automatically.
Ah that makes sense then. Was wondering how I hadn’t seen this.
Ubuntu isn’t supported as the host OS of a supervised install. There are many things different about it from vanilla debian and there is no testing done on it to identify differences prior to release. Looks like you found a new one.
I would suggest using a supported installation method.
I am running armbian buster, which is a stripped down version of debian for ARM, but facing the same issue.
