I’m running HAOS in vmware ESXi on an Intel NUC. Same issue as others - can’t get the supervisor to start. Looks like i’m running an older version of docker (19.x). How do I update the docker version when running HAOS?
Had the same issue. Running hassos on proxmox but it doesn’t have apt to update docker. What worked for me was to change the supervisor version back to 2022.05.3. In the #installation channel on the discord there is a discussion about this but here are the commands that worked for me:
This is what worked for me: docker pull ghcr.io/home-assistant/amd64-hassio-supervisor:2022.05.3 docker tag ghcr.io/home-assistant/amd64-hassio-supervisor:2022.05.3 ghcr.io/home-assistant/amd64-hassio-supervisor:latest rm /run/supervisor/startup-marker systemctl restart hassio-supervisor
I have hassio, not HassOS. And the systemd service looks for the ghcr.io repo
You can also firewall the system to block its attempts to auto upgrade.
The permanent solution was to upgrade Docker to 20.10.7
On an outdated ubuntu host, it required setting up the repo.
Is there a way to block / prevent Supervisor automatic updates? I am happy to keep my system up-to-date, but only when I am around to fix anything that breaks (and aware of what broke it)…
Nice thank you! Was down for the past few hours as I had to leave the house for a while. Came back and read through all these and got it back up and working within 5 minutes. Love home assistant and the community, even if I continue to use the pain in the butt setup haha
Guys I have figured out I am running docker 19.03.13 on ubuntu 20.04.4 on a NUC-i3
I have figured out that I need to update docker but I don’t have the skills to know to do or what to make of sense of what is written in some of the suggestions.
@ Joeviocoe seems to have listed some instructions but I really don’t understand what I am doing so need some guidance to get back on the air.
Can someone give me some help as all my ZWave is off the air as it’s an addon on in supervisor.
Thank you
This worked! Thank you so much. For some reason in the UI, I couldn’t update the OS beyond version 5.13. I forced it to update to HAOS version 7.0 via the CLI and now the docker version is 20.10.9 and the latest supervisor runs!
Thanks a lot everyone. I thought too that my SSD or rpi was dying. Did some fsck with no errors, and was going to pull up some old backup to compare the init.py file of the supervisor since it is the last line in logs before crash. Then googled “”/usr/src/supervisor/supervisor/docker/init.py"" got here directly, apt update and upgrade, back on track !
Thanks to all the great community ! Happy to have my automations back !
PS: For info I am running docker on a personalized rpi install
I was also hit by this… Running HA Supervised on a old Lenovo Tiny system. Thought the SSD had died or something, but it passed all the tests I could run on it. But kept getting the same errors without changing anything. Didn’t find this thread last night.
Ended up wiping it and switching to HA OS. Restored my last backup and was good to go again.
