I have the following problem with my LCN integration.
I have 2 door contacts that are connected to 2 binary sensors. However, the display is inverted. When the door is closed, it is displayed as open.
Greetings Michael
You can use a template binary sensor or a template helper to invert the sensor state:
https://community.home-assistant.io/t/reverse-invert-logic-0-to-1/472417.
As an alternative you might do some logic with the LED states inside your LCN modules to invert the state and display the result in HomeAssistant.
Unfortunately I canât make any progress with the suggested solutions. I have just started with HA.
Can you offer me a more concrete solution?
The binary sensor is in the module m000040.binsensor8.
The entity is called binary_sensor.tur
Thanks and regards
In your HomeAssistant frontend click on âSettingsâ â âDevices and servicesâ â âHelpersâ.
Click on âCreate Helperâ â âTemplateâ â âTemplate binary sensorâ.
Enter a new name (e.g. âDoor
â).
In state template enter:
{{ not(states('binary_sensor.tur') | bool) }}
Choose the appropriate device class (e.g. Door
Clicking on âSubmitâ creates a new inverted binary sensor which you can add to the dashboards as usual.
thank you very much it can be so easy.
If you know what youâre doing.
