LD2410 esphome tips
I have one used almost 3 months. No problem at all. Used several times a day (it is controlling light in toilet) and as I recall it had 1 or 2 cases that it did not detect movement. I find it super good and even is person is sitting still it detects presence. So I will for sure install more and will recommend.
Im using only GPIO (not using UART) output with ESPHome.
we make three type ld2410 with esphome.
we test more than 50 unit ld2410b, it’s very stable, but you need very stable power supply, and the esp board need a very good ldo power unit.
What is your esp32 yaml for using the RX and TX pins?
Are your sensors getting noticable warm as well? Mine do.
Because i want to use the LD2410 on ESPhome together with a Temperature-Sensor, i need to reduce the Heating, as it significantly influences the Readings.
I don’t a a just-in-time-Distance Reporting - an Update every 1,2,3 Minutes would be totally sufficant as well. Unfortunatly, yet logically, Deep-Sleeping the ESP doesn’t power-off the LD2410 (im using it on +5V like supposed).
Is there a Way to reduce polling frequency on the LD2410 itself, to e.g. 120s - if that would reduce the thermal heating? Or do you have a Hint how i could let the Sensor follow the DeepSleep (and Wakeup) of the ESP32? Somehow i would need to turn off +5V during DeepSleep. Or lift GND? If course only if that doesn’t stress the Hardware to get turned On/off 400 Times a Day :smiley:
The temperature of the ld2410 is relatively high, and it is not easy to reduce it. From the official personnel, we got some clues. If the detection distance gate is reduced, it will help reduce the heat dissipation temperature.
I did the same but it doesn’t work.
In my case all sensor is unknown ha ha
What should I do ?
i dont use a Esp32 i use esp8266 with wemos d1 mini, Rx ans Tx pins.
yes same, pretty hot.
you can use a Gpio to power up a mosfet, so you can shut off the ld2410 before deep sleep and power on after wake up.
the measurement of the sensor and connections:
-B=35x7mm 5 pins 1.27mm spacing
-C=22x16mm 5 pins 2.54mm spacing
they work the same
i have some c module and b module, them are work same way.
Same. I can’t get any of my LD2410C sensors to work with a D1 Mini.
Are you already using the RX and TX pins for the Wemos D1 Mini?
If it’s not, you may wanna change that and try it again.
Another thing you can check would be the baudrate.
After changing the baudrate to default value (256000) it displayed data instead of all unknowns.
I use
uart:
  tx_pin:
    number: GPIO1
  rx_pin:
    number: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
For my D1 Minis. remember RX on ld2410 to TX on mini. Been working faultlessly for months.
Still no joy :frowning:
Here’s the wiring between the D1 Mini and LD2410C.
Here’s the YAML:
esphome:
  friendly_name: presence-test
esp8266:
  board: d1_mini
external_components:
  - source: github://esphome/esphome@dev
    components: [ ld2410 ]
logger:
  level: WARN
  baud_rate: 0
web_server:
  port: 80
api:
ota:
wifi:
  ssid: !secret wifi_ssid
captive_portal:
uart:
  tx_pin:
    number: GPIO1
  rx_pin:
    number: GPIO3
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
  timeout: 150s
  max_move_distance : 6m
  max_still_distance: 0.75m
  g0_move_threshold: 10
  g0_still_threshold: 20
  g1_move_threshold: 10
  g1_still_threshold: 20
  g2_move_threshold: 20
  g2_still_threshold: 21
  g3_move_threshold: 30
  g3_still_threshold: 31
  g4_move_threshold: 40
  g4_still_threshold: 41
  g5_move_threshold: 50
  g5_still_threshold: 51
  g6_move_threshold: 60
  g6_still_threshold: 61
  g7_move_threshold: 70
  g7_still_threshold: 71
  g8_move_threshold: 80
  g8_still_threshold: 81
  - platform: ld2410
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
And here’s Home Assistant with all sensors “Unknown”.
Try setting TX and RX for the tx_pin and rx_pin instead.
I also do not have the external_components key, and I have esphome.platform defined as ESP8266, not sure if those affect.
Hope it helps!
esphome:
  platform: ESP8266
  board: d1_mini
  # ... my other device config here.
# Enable logging
logger:
  baud_rate: 0
# ...my other config
uart:
  - id: uart_bus
    tx_pin: TX
    rx_pin: RX
    baud_rate: 256000
    parity: NONE
    stop_bits: 1
# ...other ld2410 config below
level: WARN
Try removing this from the logger so it doesn’t interfere with UART0
Also, as @samuelthng says, the external component is not needed now as its native to ESPHOME
I also don’t have the external bit
esphome:
  platform: ESP8266
  board: d1_mini
I didn’t have any luck using the RX/TX pins on the D1 mini either. When I switched over to using D7/D8 then I was able to get UART data. Here is my ESPHome snippet.
uart:
  rx_pin: GPIO13  #D7
  tx_pin: GPIO15  #D8
  baud_rate: 256000
  data_bits: 8
  stop_bits: 1
  parity: NONE
Maybe worth a shot for you.
That did the trick for me!! Thanks!
I thought, my ld2410 was somehow broken, because I did not get any signal over uart.
Hi all,
I am planning on setting up an esp8266 module with an ld2410 sensor through uart.
To improve my current BLE coverage in the house I am thinking about using this esp8266 module as a bluetooth proxy as well.
Is there any incompatibility in using the same module for both usage? Just to be clear, the presence sensor would be wired and not listened to through bluetooth.
Alex
