I am trying to add an existing LED Device I have. For this, I installed the bluetooth_proxy
on an ESP32 device I have running ESPHome.
The Light is found on Home Assistant and showed to request integration. When I tried to add it, I see that the ESP32 tries to connect to it, and connects:
[15:25:02][I][esp32_ble_client:064]: [0] [78:9C:E7:0D:33:4D] 0x00 Attempting BLE connection
[15:25:02][I][esp32_ble_client:144]: [0] [78:9C:E7:0D:33:4D] Connected
But on Home Assistant the action fails with two error logs
Logger: homeassistant.components.bluetooth_tracker.device_tracker
Source: components/bluetooth_tracker/device_tracker.py:125
Integration: bluetooth_tracker (documentation, issues)
First occurred: 15:27:29 (9 occurrences)
Last logged: 15:28:09
Error looking up Bluetooth device
File "/usr/local/lib/python3.10/site-packages/bluetooth/bluez.py", line 289, in _gethcisock
sock = _bt.hci_open_dev (device_id)
_bluetooth.error: no available bluetoot devices
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 165, in perform_bluetooth_update
friendly_name = await hass.async_add_executor_job(lookup_name, mac)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/bluetooth_tracker/device_tracker.py", line 125, in lookup_name
return bluetooth.lookup_name(mac, timeout=5) # type: ignore[no-any-return]
File "/usr/local/lib/python3.10/site-packages/bluetooth/bluez.py", line 61, in lookup_name
sock = _gethcisock ()
File "/usr/local/lib/python3.10/site-packages/bluetooth/bluez.py", line 291, in _gethcisock
raise BluetoothError ("error accessing bluetooth device")
bluetooth.btcommon.BluetoothError: error accessing bluetooth device
Source: components/bluetooth_tracker/device_tracker.py:72
Couldn't discover Bluetooth devices: [Errno 19] No such device
If I try to trigger the action again ESPHome logs say Connection already established
and Home Assistant triggers the same two errors as before.
Eventually, the device disappears from Home Assistant.
Can anyone point me to what I am doing wrong?
Thank you
Edit: I also see this log
Source: components/esphome/bluetooth/client.py:519
First occurred: 21:32:50 (1 occurrences)
Last logged: 21:32:50
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.10/site-packages/led_ble/led_ble.py", line 489, in _execute_timed_disconnect
await self._execute_disconnect()
File "/usr/local/lib/python3.10/site-packages/led_ble/led_ble.py", line 501, in _execute_disconnect
await client.stop_notify(read_char)
File "/usr/local/lib/python3.10/site-packages/bleak/__init__.py", line 735, in stop_notify
await self._backend.stop_notify(char_specifier)
File "/usr/src/homeassistant/homeassistant/components/esphome/bluetooth/client.py", line 102, in _async_wrap_bluetooth_operation
return await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/esphome/bluetooth/client.py", line 723, in stop_notify
characteristic = self._resolve_characteristic(char_specifier)
File "/usr/src/homeassistant/homeassistant/components/esphome/bluetooth/client.py", line 519, in _resolve_characteristic
raise BleakError(f"Characteristic {char_specifier} was not found!")
bleak.exc.BleakError: Characteristic None was not found!
