I'm running an ESP32 to fire an ultrasonic distance sensor to check the fill level on my coffee machine. If it gets below a float-switch level, it just turns the mains power off...and always midway through a shot. The LED shows green/yellow/red for level and flashes red if there's an error. Worked perfectly with 2026.1.0. The problem I have is that with the latest versions (2026.6.3) the LED gets stuck on flashing red the moment there's a single error. Sometimes it seems it will change if the status changes - so if it's in the green level and there's an error reading the ultrasonic it will flash red and not go back to green if there's a good reading. If the level drops to yellow, that change seems to make it change the LED to yellow until the next error. Also, my logger.log attempts to diagnose this, don't seem to be working.
I don't know if there were many errors reading the ultrasonic before but I didn't notice it being a problem before; it just worked.
This might be a minor irritation...but right now it's the straw that broke the camels back!
Any pointers appreciated.
Many thanks,
Gareth
esphome:
friendly_name: ESPresso
on_boot:
then:
- light.turn_on:
effect: Booting
- component.update: fill_level
esp32:
board: m5stack-atom
framework:
type: esp-idf
substitutions:
#model Atom (grey)
rgb_pin: "GPIO27"
button_pin: "GPIO39"
ir_pin: "GPIO12"
grove1_pin: "GPIO26"
grove2_pin: "GPIO32"
#bottom pins: 33,23,19,22 25,21
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret IoT_ssid
password: !secret IoT_password
min_auth_mode: WPA2
ap:
ssid: "Espresso Fallback Hotspot"
password: ""
captive_portal:
web_server:
port: 80
version: 2
auth:
username: !secret web_server_username
password: !secret web_server_password
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: ${rgb_pin}
num_leds: 1
chipset: ws2811
effects:
- strobe:
colors:
- state: true
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 1s
transition_length: 500ms
- state: false
duration: 1s
- strobe:
colors:
- state: true
brightness: 100%
red: 100%
green: 0%
blue: 0%
duration: 250ms
- state: false
duration: 250ms
- strobe:
colors:
- state: true
brightness: 100%
red: 100%
green: 0%
blue: 0%
duration: 1s
- state: false
duration: 1s
- automation:
sequence:
- light.addressable_set:
color_brightness: 40%
red: 0%
green: 100%
blue: 0%
- automation:
sequence:
red: 100%
green: 100%
blue: 0%
- automation:
sequence:
red: 100%
green: 0%
blue: 0%
binary_sensor:
- platform: homeassistant
entity_id: switch.coffee_machine
- platform: gpio
internal: true
pin:
number: ${button_pin}
inverted: true
mode:
input: true
on_multi_click:
- timing: # Double-click
- ON for at most 1s
- OFF for at most 1s
- ON for at most 1s
- OFF for at least 0.2s
then:
- switch.turn_on: button_double
- timing: # Long-click
- ON for 1s to 3s
- OFF for at least 0.5s
then:
- switch.turn_on: button_long
- timing:
- ON for at most 1s
then: # Single-click
- switch.turn_on: button_single
switch:
optimistic: True
on_turn_on:
- delay: 500ms
- switch.turn_off: button_single
optimistic: True
on_turn_on:
- delay: 500ms
- switch.turn_off: button_double
optimistic: True
on_turn_on:
- delay: 500ms
- switch.turn_off: button_long
interval:
- interval: 10s
then:
if:
condition:
binary_sensor.is_on: coffee_machine_power
then:
- interval: 5min
then:
if:
condition:
binary_sensor.is_off: coffee_machine_power
then:
- platform: ultrasonic
trigger_pin: ${grove1_pin}
echo_pin: ${grove2_pin}
name: "Coffee Machine Fill Level"
update_interval: never
#timeout: 8m #8m minimum
unit_of_measurement: "cm"
filters:
- lambda: return 24.5-((x+0.005)*100);
on_raw_value:
then:
if:
condition:
lambda: 'return (isnan(x));'
then:
- logger.log: "Ultrasonic failed"
- light.turn_on:
effect: Error
on_value_range:
- below: 0
then:
#state Error
- logger.log: "Ultrasonic below 0"
- light.turn_on:
effect: Error
- above: 0
below: 6
then:
#state Empty (Red) - switches off about 4cm
- logger.log: "Ultrasonic 0-6"
- light.turn_on:
effect: Empty
- above: 5
below: 8
#state Warning (Yellow)
then:
- logger.log: "Ultrasonic 5-8"
- light.turn_on:
effect: Warning
- above: 8
below: 22
then:
#state OK (Green)
- logger.log: "Ultrasonic 8-22"
- light.turn_on:
effect: Good
- above: 22
then:
#state Overfull (Pulse Red)
- logger.log: "Ultrasonic 22+"
- light.turn_on:
effect: Overfill
