Thanks a lot
Interesting that this has moved on since my first post. I dug out the bulbs I had and followed along but I found that the device wifi fires up on 192.168.10.x which just happens to be my home subnet.
I’ll need to find a convenient time to shut down my wifi network to do this.
man, I owe you a (ton of) beer! That perfectly worked for me on first attempt!
Thank you!
follow the guide and tried adding as custom components but still getting unsupported device my LB1 is 0x608f according to log. maybe someone can help?
@rizkypr Put the light into AP mode (rapid flashing) by repeatedly turning on/off for 1sec in each state. From turned off, it should take 8 cycles to get to AP mode.
Once there, load up the Magic Home Lite app (android version here) and start setup of the bulb but STOP when the wifi is configured.
Add the Broadlink integration in HA and enter the IP address of the bulb from your DHCP server or static IP.
Cancel the process in the Magic Home app.
