Hi Julien,
When upgrading to the new HA Core 2022.8.0 the binary sensor (see pictures) is not available anymore.
no error logs
How can I send the Myhome log file, is a big file ?
Same setup and issue for me. any solution?
Ok i got there:
probs and solutions
first get myhome integration through HACS (custom repositories, copy and paste github link from Julien)
go to integrations, add integration, Myhome
this is where i got an error message “All MyHome gateways are already configured.” and thsi was for version 0.8.5
redownloaded in HACS and chose the ‘Master’ version
could now include custom gateway by inputting
- IP adress - you can find in myhome up app easy
- port 20 000
- MAC adress: on your gateway
- gateway: myhomeserver1
needed to add password → go to app myhomeup by using installercode, use guide as per below to change
https://www.youtube.com/watch?v=LBNdHXRVNBM
… I’m getting really tired of breaking changes every other new HA version.
I’ll have a look and report back
On HA restart, some entities do not load, quite randomly. Often it’s the binary sensors, but sometimes the sensors, sometimes the covers…
However, if you reload the integration, everything is loaded properly!
So I don’t know what’s broken, but I doubt it’s in my code.
Hi everyone,
First of all, thanks Julien for this great integration.
I have a Bticino Switch (the one with two buttons/symbols “Entra” / “Esci”) and I’m trying to use it in an Automation. I only have this 3 options (translation from italian):
-“single_press” button 1
-battery level change
-identify was pressed
I already tried to check in developer/event (* all events), but no event is generated when I press one of the two buttons. Those buttons only work in the Bticino Home Control App.
Is there a way to intercept those button in Home Assistant ?
Hi everyone, first of all I would like to thanks a lot Julien for his great work.
Than I want to ask a question: I’ve F454 system with two covers (Livinglight LN4661M2) and when I use google home to open or close those devices the command is executed, but I receive at the same time message “That mode isn’t available for your cover”.
What can I do to solve?
Tnx.
Hi @lorenzo78, if you had an actual reference for your switch, that would help.
Hi @Paolista, I don’t know anything about Google Home, but any error you get with it should be directed to their developers.
I would like to integrate into HA living now smart bus switches (like K4562M2) without Legrand server.
I switch is just a digital input for commands that will be interpreted by HA server for curtains, lights on/off, dimming, scenarios…
Is this possible with a general gateway integration (not a dedicated Legrand)?
Note: these switches do not have option to be configured as CEN devices; I looked on CEN switches (like L4651M2) but it does not seem compatible with Living Now covers.
Thank you
temporarily I have used this automation:
alias: Reload MyHome at Start
description: ""
- platform: homeassistant
event: start
condition: []
- service: hassio.addon_stdin
addon: myhome
input: reload
Hi Julien,
Here the description:
Bticino N4570CW Livinglight Entra Esci Wireless https://catalogo.bticino.it/BTI-N4570CW-IT
Thanks for the answer.
Best regards
Scusa cosa intendi per versione master?
Grazie
Hi Julien, were you able to understand the reason that the Myhome integration is not loading correctly?
My log is:
File "/config/custom_components/myhome/myhome_device.py", line 50, in async_will_remove_from_hass
del self._hass.data[DOMAIN][CONF_ENTITIES][self._attr_unique_id]
KeyError: '1-0514'
ciao @caiosweet,
ho anche io installato l ‘integrazione e tutto funziona perfettamente.
Pero’ volevo chiederti una cosa: come hai fatto a far uscire la regolazione della centrale termo con impostazioni di piu’ set di temperatura ? (l’icona della tua centrale infatti è diversa da quella delle singole zone). Io possiedo una centrale 4 zone .
Potresti aiutarmi ad impostare la mia centrale con piu’ set di temperature come la tua?
Grazie in anticipo.
Per la centrale ho usato una custom card lovelace-thermostat-card
Se vuoi avere dei pulsanti per 3 o 4 temperature da settare, puoi usare button, ad esempio:
type: button
show_state: false
show_icon: false
tap_action:
action: call-service
service: climate.set_temperature
service_data:
entity_id: climate.termo_central_unit
temperature: 18
“climate.termo_central_unit” va sostituito con la tua entità relativa alla centrale…
se ti serve il codice della card fatta un paio di anni fa, fammi sapere.
Ciao @caioswwer, grazie per la risposta, se puoi passarmi il codice della carta te ne sarei davvero grato, io sono alle prime armi con home assistant
Ci sono un po’ di card custom e la card è un po’ vecchiotta…
MyHome Climate card
type: custom:vertical-stack-in-card
cards:
- type: horizontal-stack
cards:
- type: vertical-stack
cards:
- type: custom:thermostat-card
entity: climate.termo_central_unit
title: Centrale
ambient_temperature: sensor.temperatura_media_bticino
cards:
- type: button
state_color: true
entity: binary_sensor.boiler
show_state: false
show_name: false
show_icon: true
tap_action:
action: more-info
- type: button
show_state: false
show_icon: false
tap_action:
service_data:
temperature: 10
- type: button
show_state: false
show_icon: false
tap_action:
service_data:
temperature: 18
- type: button
show_state: false
show_icon: false
tap_action:
service_data:
temperature: 19
- type: button
show_state: false
show_icon: false
tap_action:
service_data:
temperature: 20
cards:
- type: grid
columns: 2
cards:
- type: custom:mini-graph-card
entities:
- sensor.temperatura_camera
align_header: center
align_state: center
line_color: var(--accent-color)
line_width: 8
font_size: 70
show:
icon: false
entities:
- sensor.temperatura_studio
align_state: center
line_width: 8
font_size: 70
show:
icon: false
- type: grid
columns: 2
cards:
entities:
- sensor.temperatura_bagno
align_state: center
line_width: 8
font_size: 70
show:
icon: false
entities:
- sensor.temperatura_sala
align_state: center
line_width: 8
font_size: 70
show:
icon: false
cards:
- type: thermostat
entity: climate.termo_camera
title: Camera
- type: thermostat
entity: climate.termo_studio
title: Studio
cards:
- type: thermostat
entity: climate.termo_bagno
title: Bagno
- type: thermostat
entity: climate.termo_sala
title: Salone
grazie @caiosweet ,
ma queste impostazioni li devo mettere in una nuova card oppure nella card del termostato lovace?
Se è da inserire nel termostato lovace , li’ non mi fa scrivere nessuna configurazione.
mi da errore, forse perchè ci sono piu’ sensori, io ho solamente la centrale 4 zone e la sonda h4691 che mi dà la temperatura nella camera delle bimbe
