Unfortunately there is no real documentation about that attribute.
A short and not very clear description is here:
In my opinion, maybe it means that the cover entity could assume the state is close or open as soon as it receive the close or open command respectly, regardles if the cover is really in that state (an optimistic assumption).
I found a similar behavoiur in Homebridge that has the possbility to declare in an attribute the timing the shutter requires for closing. Based on that timing you can define a percentage of closure of the shutter, because the entity records automatically the timing of the command duration.
Do you think something like one of these features can be implemented?
From what I can see, that attribute is only present in the Template cover, not in the actual cover entity.
If Home Assistant plans to add a function supporting this in the cover entity, I’ll be glad to implement it.
I’m not planning, however, to add these functionalities if they are not supported in the wider Home Assistant system.
Sorry if my question is stupid but i am not familiar with HA.
I tried to install your integration through HACS and all seems ok.
HA is installed on RPI through HAos so i have HA supervisor and if i understand well several container.
when i launch your integration, it doesn’t find any server (i have a f454)
I installed ssh addon to troubleshoot but it seems i am on the host and can’t go on HA container.
i tried docker commad but doesn’t find it…
so i installed HA on a synology and same thing: no server detected
this time have access to ssh on HA container and i pushed command: python3.8 /usr/local/lib/python3.8/site-packages/OWNd/discovery.py
I didn’t get any result (that explain why your integration didn’t find any server)
I tried this command: python3.8 -m OWNd -v 2 -a 192.168.0.15 -p 20000 -P 12345
and get this result:
2021-02-10 19:37:35,953 - OWNd - INFO - Starting OWNd.
2021-02-10 19:37:35,953 - OWNd - INFO - Opening event session.
2021-02-10 19:37:35,956 - OWNd - DEBUG - Negotiating event session.
2021-02-10 19:37:35,960 - OWNd - DEBUG - Reply: *#*1##
2021-02-10 19:37:35,962 - OWNd - DEBUG - Reply: #1##
2021-02-10 19:37:35,962 - OWNd - INFO - Event session established.
2021-02-10 19:37:36,080 - OWNd - DEBUG - Received: 1501#388##
2021-02-10 19:37:36,081 - OWNd - INFO - Button 1 of CEN object 88 is being held pressed.
2021-02-109:37:36,561 - OWNd - DEBUG - Received: 1501#388##
2021-02-10 19:37:36,561 - OWNd - INFO - Button 1 of CEN object 88 is being held pressed.
Your gateway not being discovered would probably indicate that it is somehow not broadcasting with SSDP.
If you are running Windows, you should see your gateway discovered in the “Network” part of Explorer.
Is it the case?
I am running MacOS, I have an old Windows that i will try to start tomorrow but not sure that it will be operational.
If my f454 is not broadcasting with SSDP what is the solution? is there a configuration to apply to f454? why my f454 doesn’t broadcast with ssdp? my understanding is that you use a f454 or several users have this gateway and don’t meet any issue.
I tried to find some info through google but nothing except a tuto on how configure windows 7
As far as I know, there are no settings you can change on the F454 for that…
Indeed I am using the same type of gateway, as are others without any problem.
I forgot to ask, but is you gateway in the same network as your Home Assistant installs?
thanks for your answer
my gateway is on the same network than my Rpi and my synology (192.168.0.0/24)
But as I installed HAos, my understanding is that there are several container and the HA container has an IP similar to 172.x.x.x
So not sure how docker manage his own network and if you consider that the same network.
I read in the thread that some have installed HA with supervisor on rpi , so for me it’s HAos with container.
Is there a way to force the gateway in configuration.yaml or in another file?
I have a MH202 in my network, and MH202 isn’t recognize too
EDIT:
I checked with a windows workstation and in “network”, i can see my gateway and my MH202
That’s very weird… If your gateway(s) are visible in your network, it means they do send SSDP multicasts just fine, HA should be able to detect them!
I run Hassos on a RPi 4 at home, and the HA container can see the multicast traffic with no problem.
I really don’t know what could be wrong here.
Unfortunately, there is no way to manually add the gateway in YAML either…
I found what was the trigger of the issue: IGMP snooping was enbaled on the switch.
After disabled IGMP snooping, the discover process works perfectly
many thanks for your help
Provided the requirement part of the manifest has been updated (either manually, or because of a new version from the component itself), yes, it’s all that is required
I’m not familiar with HomeUp Server, what is it?
If it’s the newer “MyHOMEServer1”, then yes, it does!
Overall, it should work with anything that can act as an OpenWebNet Gateway.
