Legrand/Bticino MyHome
I’ve installed the integration and receive following error message:
==> problem solved, was syntax error in yaml
Logger: homeassistant.config_entries
Source: config_entries.py:402
First occurred: 12:29:22 AM (1 occurrences)
Last logged: 12:29:22 AM
Error setting up entry F452 Gateway for myhome
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 402, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/myhome/__init__.py", line 51, in async_setup_entry
    _validated_config = config_schema(yaml.safe_load(await yaml_file.read()))
  File "/config/custom_components/myhome/validate.py", line 177, in __call__
    data = super().__call__(data)
  File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 272, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
    return base_validate(path, iteritems(data), out)
  File "/usr/local/lib/python3.11/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
    raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected a dictionary for dictionary value @ data['f452']
I’ve been having a problem with integration for a few days now. when I load my dashboard everything works, but after a few minutes the communication stops and I have to reload the integration. then it works again for a few minutes.
I got this text from my log.
Logger: home assistant
Source: custom_components/myhome/light.py:220
Integration: MyHome (documentation, issues)
First occurred: 23:13:02 (1 occurrences)
Last logged: 23:13:02
Error doing job: Task exception was never retrieved
File “/config/custom_components/myhome/gateway.py”, line 308, in listening_loop
self.hass.data[DOMAIN][self.mac][CONF_PLATFORMS][_platform][message.entity][CONF_ENTITIES][_entity].handle_event(message)
File “/config/custom_components/myhome/light.py”, line 220, in handle_event
self._attr_is_on = message.is_on
File “/usr/local/lib/python3.11/site-packages/OWNd/message.py”, line 482, in is_on
return 0 < self._state < 32
TypeError: ‘<’ not supported between instances of ‘int’ and ‘NoneType’
Does anyone know how I can solve this problem? it ran for a few weeks without any problems. and I have no idea what has changed now, other than the “2023.12” update.
I also went back to an older backup, but that didn’t work either unfortunately.
forgot to say, I’m now connected via an MH200N. but also have a Myhomeserver1 in the installation. but I was unable to connect via the Myhomeserver1
Hi Speedermenn have you solved? I’ve the same problem.
Tnx.
has anyone tried to integrate bticino sound diffusion with f500 radio tuner, rca input L4560 and special controls L4562?
I’ve just started with Home Assistant and I’m using this integration to control my lights through my MH200N Gateway and it’s working great.
Can it also be used to receive input signals? Some of the light switches in my house aren’t assigned to any lights. Is it possible to receive their on/off/dim signals thru this integration in Home Assistant and then have Home Assistant do something with them in Node-RED?
Hi everyone, sorry for my poor English. I have an F521 energy consumption detector, and the problem is that it doesn’t update automatically. I’ve tried in a thousand ways but nothing works! The only way to get it going was by writing a script, but after 256 calls (around 4 hours), it stops functioning. Is there any other way? I’m a beginner, so please explain it with some examples. Thanks to anyone who can help me.
alias: power_bticino
sequence:
  - service: myhome.start_sending_instant_power
      entity_id: sensor.attuale_attuale_power
      duration: 255
icon: mdi:account
mode: restart
Hello everyone,
I’m quite new in the HA ecosystem. I installed HA for the first time and tried to connect my Bticino MyHomeServer1. First, I followed the steps on this page BTicino - Home Assistant (home-assistant.io). The intragration was completed, but no devices are visible.
After googeling a while I came across this thread, which I havn’t read completely to be honest.
I followed the link to github, but was unsure how to proceed.
At this point I was unsure if my installed integration is the same as the myhome from this thread. If so, I don’t get it how I can configure my devices. If not, I don’t get it how to install this integration.
It would be great if you guys can help me, to achive the next step in my young HA career to integrate my bticino MyHomeServer1.
Thanks in advance :slight_smile:
Hi, you need to write the .yaml configuration. Look the Wiki in the GitHub page, is very clear.
How did you manage to edit the part for the message so that it includes the bus address?
I would really like to implement this as well, but i don’t know where to start, i searched all the folders for the message.py file but i can’t find it. So I’m probably looking in the wrong place. WOuld be great to hear from somebody.
Tnx
my integration on raspberry 4 crashes from time to time. I have to restart integration to get everything working below the debug file
Hi Julien and your collaborators. I just wanted to thank you all for a fantastic integration. I have a large MyHome installation supported by a number of other smart home appliances nin various platforms. Your integration has allowed me to change from using a cocktail of apps to control my home to being able to consolidate everything into HA and build a very functional smart home, including switching my MyHome lights with various sensors and remote switches. I wanted to make a donation to acknowledge your valuable work, but can’t see a link to a Peatrreon account or something similar?
Hallo: new to HA and having many troubles with this integration.
This configuration does not work: only the first light is shown in HA.
Any help?
myhomeserver1:
  mac: '00:03:50:xxxxxxxx'
  switch:
    outlet1:
      where: '25'
      class: outlet
      manufacturer: BTicino
      model: F411U2
  light:
    light1_bedroom:
      where: '92'
      dimmable: False
      model: F411U2
  light:
    light2_bedroom:
      where: '93'
      dimmable: False
      model: F411U2
Hi all,
I tried today to install MyHome integration using HACS.
It gets installed correctly (as far as I can tell). However after the restart of HA cannot find any mention of my own MyHomeServer1 instance in the UI of HA.
Where I should be looking for?
Is that a sign that auto-detection has failed?
In such case which log files I can check?
thanks!
Hi, i’m in the same way. I’ve installed MyHome on HA and i had to create mannually myhome.yaml
But… where i can find the “where” code i have to use to identify the light i’m trying to reach??
I’m doing this in my myhohe.yaml
light:
salon:
where: ‘08’
dimmable: False
model: F411U2
But “where” number is invented by me.
Can someone help, please!!
Hi! Where do you get the “where” number??? I don’t know how to get them.
SOLVED! I need to use OpenWebServer Client, connect to the MyHomeServer1 and read the bus to catch the “where” number. Ex: 11*0210## My “where” number for this light is 0210.
the F441 is just a bunch of amplifiers and an analog bus. there is nothing to control
The gateway is acting as a clock master on the bus. and broadcasting current time every 10mn.
The idea would be good, if Bticino had bothered implementing an NTP client on the gateways… But they didn’t, so that clock is awfully inacurate
buongiorno a tutti,
sto iniziando a configurare HA con questa integrazione, come posso collegare il mio mhs1 (aggiornato ad home+control)? qualcuno può aiutarmi? ho letto di creare un file /config/myhome.yaml e fin qua ci siamo, ma dentro il file cosa devo scriverci? grazie tante
Good morning everyone,
I’m starting to configure HA with this integration, how can I connect my mhs1 (upgraded to home+control)? can someone help me? I read about creating a /config/myhome.yaml file and that’s it, but what should I write inside the file?
Thanks :slight_smile:
Can someone tell me how to configure a group in the yaml file.
All shutters that are in 3.x should be lowered.
Lg
Franz
