just tried it and now I can see my A/C units in Home assistant now Thank you
Thanks for the update.
I see the following errors on the logs. I would open an issue on github but seems that they are not enabled:
#1:
2021-04-19 16:41:15 ERROR (MainThread) [homeassistant.components.climate] Error adding entities for domain climate with platform thinq_v2
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 322, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 429, in _async_add_entity
capabilities=entity.capability_attributes,
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 190, in capability_attributes
ATTR_HVAC_MODES: self.hvac_modes,
File "/config/custom_components/thinq_v2/climate.py", line 221, in hvac_modes
return [
File "/config/custom_components/thinq_v2/climate.py", line 225, in <listcomp>
in self._ac.model.value("airState.opMode").options.values()
File "/usr/local/lib/python3.8/site-packages/wideq/client.py", line 347, in value
d = self.data["Value"][name]
KeyError: 'airState.opMode'
#2
2021-04-19 16:53:56 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [1648798856] 'NoneType' object has no attribute 'is_on'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 143, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1515, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 206, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 649, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 692, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 686, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 434, in async_set_hvac_mode
await self.hass.async_add_executor_job(self.set_hvac_mode, hvac_mode)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/thinq_v2/climate.py", line 291, in set_hvac_mode
if not self._state.is_on:
AttributeError: 'NoneType' object has no attribute 'is_on'
I have mixed v1 and v2 devices so not sure this is the reason for those errors.
Thanks a lot for the work Marcio! I can confirm it’s been working flawlessly for a week or so. I just hope it will take some time until LG changes their API again.
@marciogranzotto, thanks for your work on this.
I’m able to successfully install the component for my LG AC unit via HACS and link my account but getting climate errors in HA now.
(Error) Climate
The thinq_v2 platform for the climate integration does not support platform setup. Please remove it from your config.
(Error) Sensor
The thinq_v2 platform for the sensor integration does not support platform setup. Please remove it from your config.
(Error) custom_components/thinq_v2/climate.py - message first occurred at 11:44:45 AM and shows up 9 times
I’m running core-2021.4.6. Anyone know why I’m seeing these errors? Am I missing something?
can you post the detail log of this error?
Probably there will be AC models that don’t have some of the fields that mine has. We need to experiment with different ACs and start changing the integration to be null safe
Here you go. The window AC unit is the LW1019IVSM. Thanks
Logger: homeassistant
Source: custom_components/thinq_v2/climate.py:244
First occurred: 11:44:45 AM (461 occurrences)
Last logged: 7:24:49 PM
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 626, in _update_entity_states
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 297, in async_update_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 336, in _async_write_ha_state
attr.update(self.state_attributes or {})
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 269, in state_attributes
data[ATTR_SWING_MODE] = self.swing_mode
File "/config/custom_components/thinq_v2/climate.py", line 244, in swing_mode
if v[0] == self._state.horz_swing and v[1] == self._state.vert_swing:
File "/usr/local/lib/python3.8/site-packages/wideq/ac.py", line 440, in horz_swing
lookup_enum("airState.wDir.hStep", self.data, self.ac)
File "/usr/local/lib/python3.8/site-packages/wideq/util.py", line 17, in lookup_enum
return device.model.enum_name(attr, data[attr])
KeyError: 'airState.wDir.hStep'
Hello, I have AC LG PC09SQ, sensors and entities are not created either. Error log:
Logger: homeassistant.components.climate
Source: custom_components/thinq_v2/climate.py:225
Integration: Климат (documentation, issues)
First occurred: 23 апреля 2021 г., 15:17:57 (1 occurrences)
Last logged: 23 апреля 2021 г., 15:17:57
return [
Similar error with a LG LP1419IVSM. Can execute commands, but no sensor data is being returned. Error is:
In the entity itself, these are the values being returned with a state of unknown:
hvac_modes:
- auto
- auto
- heat
- cool
- fan_only
- dry
- heat_cool
- 'off'
min_temp: 18
max_temp: 30
fan_modes:
- low
- low-mid
- medium
- mid-high
- high
- power
swing_modes:
- 'Off'
- Vertical
- Horizontal
- Vertical and Horizontal
- Up Left
- Up Right
- Up
current_temperature: null
temperature: null
fan_mode: null
swing_mode: Unknown
friendly_name: Air Conditioner
supported_features: 41
I ran into the same thing on my 2 window units
mine are the
Dual Inverter
Model # LW1517IVSM
after flopping around like a gut shot squirrel I finally found the solution on git hub, though not very clear
first off you need to locate your thinq_v2 folder that is located in the custom_components folder in home assistant folder
you need to edit the init.py file and the climate.py file I used notepad++ to do it
I linked to both files to make it easier
here is what I used to edit them
climate.py line 43
and
climate.py line 243
line 243, change from if self._swing_mode == SWING_MODE_DEFAULT and self._state is not None:
to
if self._swing_mode != SWING_MODE_DEFAULT and self._state is not None:
once you have edited the files restart your home assistant and then power cycle the ac unit in home assistants card it should then send back the info
This completely solved my issue, appreciate your help! Hopefully these changes will be in an upcoming update.
Thanks for sharing this info @trentjw . I tried the changes you posted (though maybe I did something incorrectly) and I am able to mostly control my window unit now but still seeing errors in the logs. I also get some errors when trying to change the fan speed even though the command seems to work. In the lovelace thermostat card I see various settings that don’t apply to my unit:
- various fan speeds other than high, medium and low
- Two options for auto
- swing mode (which is greyed out)
Source: custom_components/thinq_v2/climate.py:245
First occurred: 12:52:38 PM (151 occurrences)
Last logged: 3:22:40 PM
File "/config/custom_components/thinq_v2/climate.py", line 245, in swing_mode
Logger: homeassistant.components.websocket_api.http.connection
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:51:48 PM (7 occurrences)
Last logged: 12:53:07 PM
[140134379861280] 'airState.wDir.hStep'
[140134351998496] 'airState.wDir.hStep'
task.result()
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 666, in entity_service_call
Source: helpers/entity_platform.py:133
Integration: Climate (documentation, issues)
First occurred: 12:46:34 PM (1 occurrences)
Last logged: 12:46:34 PM
Logger: homeassistant.components.sensor
Integration: Sensor (documentation, issues)
the card will show a bunch of stuff that does not apply this LG thing is clunky at best right now
just a few days ago it was not even working as good as it is now in fact I only was able to get Home assistant to see them with the marciogranzotto’s last update,
my logs suggest I should remove it as well but it is working so I ignore the error for now LOL
did you edit line 243 so the == is now a != as your log shows otherwise
Thanks @trentjw. This is what I have in my climate.py. The change is there and correct, I think.
@property
def swing_mode(self):
# try to find out if the (initial) state matches a known state actually
for k, v in swing_modes_index().items():
self._swing_mode = k
break
else:
return SWING_MODE_DEFAULT
I believe the spacing is correct. I will try uninstalling the component and starting over with a clean set of files.
Hi, i install the github in hacs. I install the LS SMARTHTHING V2.
Sorry but i don’t understand what to do After.
Just go to Configurations > Integrations and add the Smartthinq v2 Appliances integration and follow the instructions that will appear
did you get it working?
Many thanks, all are ok !!!
