I have older LG OLED TV LG 55EG910V-ZB that has WebOS 2.0 (updated to the lates version).
I added it to HASS and in shows up fine. Everything seems to be working and I can turn it off just fine. But I can not get it to turn on with WOL. Here is my config.
When I first added the TV to HASS I did not add the turn_on_action and I was wondering that should I repair the TV after I added the turn_on_action? I did try that but do not know how to remove the pairing because when I deleted the webos config and rebooted and added it again it just showed up normally. I do use ethernet and I have disabled WLAN on the TV.
If I turn TV off from the app, it just says that connection lost to the TV and does not find it again until I turn TV on.
I was thinking on making a script that turns the TV on with chromecast since that is doable from the HA gui ATM. And then create an automation that changes the source to āLive TVā when TV is on.
According to LG, my TV does not support WOL. Turn on actually works like 2 minutes after turn off but most likely the TV turns off network stack soon after that
So my best option is to use Chromecast and then change the source in automation or something like that.
Does anyone know how to call the service turn on of media player in HA in script?
Followed official docs and didnāt work.
Turned on every feature I found on my TV, and didnāt work. And it seemed weird to me that my TV did not support WOL since itās relatively new (2017) and a good model (4K w/ HDR+ etc)ā¦
Followed your suggestion and it now works fine (both ON and OFF features) from HA:
# LG TV
media_player:
- platform: webostv
host: 192.168.xxx.yyy
timeout: 5
turn_on_action:
service: switch.turn_on
entity_id: switch.lg
switch:
- platform: wake_on_lan
mac_address: "aa:bb:cc:dd:ee:ff"
Remember to change your IP address and MAC to match your TVās.
Also I read somewhere that, if running HA in Docker, then you need to start your container with --net=host. After some testing I can confirm this is correct. If network_mode is bridged WOL wonāt work.
Hope this helps. It was driving me nuts for a while.
Hi, Iāve been trying to run this config for my LG model (2016 4k one) but none of them seems to work (the switch configuration workaround).
Anyone there still with the same problem?
Am I missing something here? LG C9 and I canāt get it to turn on via HA. I have the ThinQ app downloaded and can turn it on from there no problems⦠I can only get HA to turn it off using the belowā¦
wake_on_lan: # enables `wake_on_lan` domain
webostv:
host: 192.168.0.10
name: Living Room TV
turn_on_action:
service: wake_on_lan.send_magic_packet
mac: AA-BB-CC-DD-EE-FF
broadcast_address: 11.22.33.44
customize:
sources:
- Plex
- Netflix
- YouTube
- Live TV
media_player:
notify:
Executing a turn on function produces the following in the HA logs:
2020-09-24 22:50:13 INFO (MainThread) [homeassistant.helpers.script.living_room_tv] Living Room TV: Running webostv script
2020-09-24 22:50:13 INFO (MainThread) [homeassistant.helpers.script.living_room_tv] Living Room TV: Executing step call service
2020-09-24 22:50:13 INFO (MainThread) [homeassistant.components.wake_on_lan] Send magic packet to mac AA-BB-CC-DD-EE-FF (broadcast: 11.22.33.44, port: None)
And nothing happens so obviously the MAC is my TV Mac Address, but what should the 11.22.33.44 address be? And do we need to define a port?
EDIT: After reading through some HA isues, I found Issue #36231 which suggest turning on HA while the TV is ON, which resolves the issue.
Possibly. I know that, at least the very first time, the TV has to authorize Home Assistant (you get a popup on the TV) to remote control it. Now, whether you need the TV on first or notā¦I do not know. Theoretically HA pulls constantly its componentsā¦so I dunno.
Then, remember that for WOL to work, you need to run HA directly on ābare metalā or if in docker, it must be using a āhostā network container.
I know this is old but I just finished setting mine up and trouble with this⦠then I got it and went through the SAME troubles with my other TV⦠I figured I would post here in case anyone has issues and finds this thread.
TV1: LG 43UJ63 43" 4K WebOS from September 2017
"About This TV" Menu Software Version: 06.00.03
TV2: LG 55UM69 55" 4K WebOS from September 2019
"About This TV" Menu Software Version: 05.10.05
NOTE: Both TVs are updated as of today. (June 30, 2021) Strange thing is the older TV updated to a higher firmware version, but both say no updates available now.
NOTE 2: I have no idea if it is relevant or not, but the OS looks the same on both TVs (colors, menu structure, images, etc) and has since Day 1, except a few little differences:
When you push the settings button on the remote, a little ābasic menuā pops up with circle icons. On TV1 that appears on the right. On TV2 it appears on the left. Both have the same items listed, and clicking āAll Settingsā opens the real menu on the left on both.
In the TV1 Network menu there is āLG Connect Appsā with a toggle for On/Off and nothing else. In the TV2 Network menu there is no āLG Connect Appsā menu, but there is a āMobile TV Onā menu and it has a toggle for āTurn On Via WiFiā. These are turned on on mine.
Notice that TV2 (Living Room) required the technique of creating a switch with platform: wake_on_lan and the field for MAC Address has the key AND the value in quotes. It did not work without the quotes. Mine also did not work without the broadcast address. For MOST home networks you have a subnet of 255.255.255.0 and if yours is then your broadcast address will be just like your IP address except the last octet will be 255. (For example: if your IP is 10.0.0.xx, your broadcast address for the network is 10.0.0.255. If your IP Address is 192.168.1.xx, broadcast is 192.168.1.255, etc) Mine did not work without the broadcast address. This did NOT work at all on TV1.
Notice TV1 uses the technique where you can just add a turn_on_action calling service wake_on_lan.send_magic_packet (Note that it now has .send_magic_packet appended to the end where for the switch it only needed to call the āwake_on_lanā object) and then attach a data object with the fields for "mac" and broadcast_address following the same guidelines as shown for TV2. This did NOT work for TV2.
Looking around there were so many different answers from so many different years. It is not as relevant which version of HA as it is which TV and firmware it is. Donāt judge based on post date, try both ways and if you have multiple TVs and one just wont work try making that one the other way and that just might do it!!
Watch 5 youtube videos and couldnt get my newer LG to work, the Switch method seemed to work when written into config.yaml
# TV
switch:
host: 00.00.00.191
"mac": "XX:XX:XX:XX:XX:XX"
broadcast_address: 00.00.0.255
webostv:
host: 00.00.00.191
name: Bedroom LG TV
turn_on_action:
entity_id: switch.Bedroom_LG_TV_turnon
customize:
sources:
- AV
- All 4
- Amazon Prime Video
- BBC iPlayer
- Component
- DuplexPlay
- HDMI 1
- HDMI 2
- HDMI 3
- ITV Hub
- LG Content Store
- Live TV
- Music
- My5
- NOW
- Netflix
- Photo & Video
- Rakuten TV
- Sky Store
- Web Browser
Guyz,
just out of curiosity. I know that its different thread but when i open netflix it is asking for profile to choose. So basicaly i cant control it from the home assistant. just change the sources. Do you have solution how to control it? Or must use their app?
