Lidl Melinera Christmas String (HG06467 - LIDL Livarno Lux)
I bought today this nice Lidl Melinera Christmas String with Zigbee. I am using DECONZ. Genrally all fine, except setting uup effects.
Those effects are avaible: “steady”,“snow”,“rainbow”,“snake”,“twinkle”,“firework”,“horizontal_flag”,“waves”,“updown”,“vintage”,“fading”,“collide”,“strobe”,“sparkles”,“carnaval”,“glow”.
I can set them via REST-API:
curl -H ‘Content-Type: application/json’ -X PUT -d ‘{“effect”:“sparkles”}’ http://172.30.33.2:40850/api/33E7B7A7B7/lights/14/state
with success
or
curl -H ‘Content-Type: application/json’ -X PUT -d ‘{“effect”:“snow”,“speed”:100,“colors”:[{“r”:164,“g”:168,“b”:50},{“r”:168,“g”:50,“b”:153},{“r”:102,“g”:50,“b”:168},{“r”:50,“g”:155,“b”:168},{“r”:50,“g”:168,“b”:72},{“r”:168,“g”:88,“b”:50}]}’ http://172.30.33.2:40850/api/33E7B7A7B7/lights/14/state
with error and success
On GUI of Hassio for effect only “colorloop” is shown.
Please integrate a feature to overwrite standrad effect “colorloop”.
Thanx!
Thanks for the information your post provides. I created a override for my melinera christmas string the following way:
homeassistant:
  customize:
    light.color_dimmable_light_19:
      effect_list:
        - steady
        - snow
        - rainbow
        - snake
        - twinkle
        - firework
        - horizontal_flag
        - waves
        - updown
        - vintage
        - fading
        - collide
        - strobe
        - sparkles
        - carnaval
        - glow
it’s showing up fine in web ui, but does not work. Will try with your api call… What api endpoint you are sending the calls to? phoscon or homeassistant?
I send them via HA bash to DECONZ-Rest-Api.
Seems that something was done:
Yes, Im gonna try add them so they’re usable in home assistant as well. In good time before Christmas :slight_smile:
@Robban @JayTee75
How did you solve it? I just put up the tree with the lights, used the customization.yaml The effects are shown but the light is not responding. Only normal colors are working.
I am using it with deconz. REST Api is working
I just tried it today too with customization.yaml. No success. Any ideas?
Maybe next year… :frowning:
Hi Robban, it’s working for you. Xmas is coming :wink: So can you give a hint to use it?
I don’t have the Xmas lights myself. I will have to add explicit support in the integration for the effects. Right now it’s only supported din the library
ahh, I see. Thanks for the infomation. Do you will integrate it before december?
:slight_smile:
PR is up to support this, I hope it will be part of 2023.11 release.
@Robban Thanks for the good news :slight_smile:
@Robban Was this tested with actual hardware?
I have the HA deconz addon 6.22.0 and HA 2023.12.0b1 but colorloop is still the only effect the selector presents me.
No. I go on data I scrape together. There are way too many devices supported by deconz.
I expand thw effects list on the device model “TS0601”
OK understandable. Can I help debugging it?
Yes can you start by validating the device model?
It will help with creating an issue on home assistant github
Ok - mfg id is _TZE200_s8gkrkxk and model id is TS0601
The Phoscon webinterface lists it as LIDL Livarno Lux HG06467
The issue should be opened at the core repo right?
edit: I verified that the effects are triggerarble by REST
Yes that’s correct
Do you see the other effects populated for the light?
