Released 0.5.3
- Delay & more retries for error 403 while fetching Member data
- Fix bug when disabling account
- Move “client” request to background task
- Display retry attempt number in debug message
Released 0.5.3
This would make sense why mine isn’t working still. I’m on 2024.6.4. 2024.7.0 breaks something for me so I haven’t upgraded yet. Maybe I’ll go ahead and try it this weekend. Do you know if the token i have saved will work or would I need a new one?
dj
Phil I think you are on to something. I upgraded to the latest HA and my Life360 is working again.
dj
Is there a way to get the Life360 Zones into HA Zones? Or does it or will it happen automatically?
I just discovered I had a hard-coded zones.yaml file that was old and not being updated. I removed it from the configuration.yaml and restarted. Now HA only sees one zone: “Home”.
Thanks!
-Tim
No. There used to be a way to get the Place details in the debug log, which was printed in a format that made it easy to copy & paste into a zones.yaml file, but that feature wasn’t added when I rewrote the integration from scratch recently.
@pnbruckner, so are you saying the intgration is back? are the details in thew OP or do you have a link you can share to the repo?
I am on my last month of life360 and If the integration works again I will keep the dang service…
It’s still not sure if it will keep working. We are testing it, but it has changed a couple of times now in the last few months. It has been working for some people again for 2 weeks now I think. But no guarantees.
You can find the integration here:
pnbruckner/ha-life360: A Home Assistant integration for Life360. (github.com)
As @frits1980 says, no guarantees. Seems to require HA 2024.7 or later.
Released 0.5.4b0
Released 0.5.4
Damn, seems like it broke for me… and now the 3b is not working either… ![]()
What HA version are you using? I assume you mean it was working, but when upgrading to 0.5.4b0 it stopped working, yes? Exactly how did it break?
Using 2024.11.1 and 0.5.4b0
Got the:
Noticed one thing…
Did a logout and login and it seems like its only works with verification keys.
It didnt even ask for password, instead it send me a verification key to my email…
Fixed… Did the token variant… and now it works!
Anyone’s devices suddenly become unavailable?
Tried deleting the integration and connecting via the token method instead but still no dice
Working here.
User error I think! When trying with the token method, I wasn’t selecting ‘Done with accounts’ so it wasn’t saving it!
Hello,life 360 not working with HA 2025.01
this error
Setup failed for custom integration ‘life360’: Unable to import component: cannot import name ‘LENGTH_FEET’ from ‘homeassistant.const’ (/usr/src/homeassistant/homeassistant/const.py)
Thanks. I’ll work on a fix soon.
UPDATE:
Actually, that was fixed a long time ago. You need to update the integration.
Could be setup specific, working fine for me after upgrade to 2025.1.
Also for me after the 2025.1 upgrade. Tempting fate again but it’s been rock solid for months now…
