Thank you Phil!
PR for documentation submitted.
Note that for users of the custom component this will represent several breaking changes. I already commented on a few of those above. A more complete list can be seen here, or by reviewing the proposed documentation page.
Hi Phil
Upgraded to 0.92 and it broke life360, so reinstalled from the last code copying the life360 folder into custom_components folder - this after I went back to my previous version of HA ( 091.4)
Then tried to follow the instructions to install the custom_updater component, but found the instructions are not right: on the link ( https://github.com/custom-components/custom_updater/wiki/Installation) says to copy the custom_updater.py to a new folder called custom_updater. It turns out on the Zip file, there is no file with that name ( there is a folder, yes)
anyway, I run the custom_updater install service, then the custom_updater.check_all and restarted HA
Iām not sure if it has done anything, as I still getting a warning saying: āYou are using a custom component for life360 which has not been tested by Home Assistantā
Iām scared of upgrading back to 0.92 as I suspect it will fail again
Any suggestions?
I canāt comment about custom_updater. I didnāt write it.
You donāt have to use custom_updater to install life360. You can, but you donāt have to. There are manual installation instructions for life360 if youād rather do that.
So you say you upgraded to 0.92 and life360 broke. Can you be more specific? What broke & how? Are there error messages? If so, can you post them? Are you using the latest version (2.9.5, or at least 2.9.4)?
Iāve gotten some reports of life360 not working after upgrading to 0.92, but none of them have been proven to be a real issue. Either it was an old version of life360, or it wasnāt installed correctly, or something like that. Iām happy to try and help, but Iāve tested it extensively with many versions of HA, including 0.92.0. I even went through an experiment today where I installed it on 0.91.4, then upgraded to 0.92.0, and Iāve yet to find where it doesnāt work, as long as itās at least version 2.9.4.
Phil
Iām impressed: this was a really quick reply!
I did reinstall life360 a couple of weeks back, as I was worried a new version would break it, so it couldnāt be too old, I replaced the old system that had two .py files to just one, and it was working until I upgrade to 0.92
After the upgrade HA could not report any tracking data
Unfortunately, I did revert to the previous snapshot, so all the logs are now gone
As I have reinstalled everything , now is running on the last release ( 2.9.5) - but Iām still getting the warning message about life360 -not sure if is relevant or not
Is there any way of testing it - before the upgrade to 0.92?
Itās really painful to revert to an older snapshot, but if that is the only way of testing itā¦
Sorry I cannot provide a lot of information
Let me know , and I can try again
Javier
All the work I did to make it work with 0.92 started with version 2.9.1 on 4/19, and I didnāt get it completely right until version 2.9.4 I released on 4/22. So anything older than 4/22 (i.e., older than 2.9.4) will probably fail on HA 0.92.0+.
Thatās good!
HA will always warn about custom components/integrations. We just have to live with that. Itās actually a good sign because itās at least finding it!
You canāt test if it will work with 0.92 unless you install 0.92. But Iāve done that and I know it will work. I understand the pain, but I canāt see anyway to avoid it if you want to upgrade. If you do upgrade to 0.92, and you still run into problems, letās diagnose it and fix it. I would recommend at least setting logger to debug. That way you should be able to see if/what life360 is doing in home-assistant.log.
Thanks for your reply
I will probably try tomorrow
I already have the log in debug
And will let you know once I do it
Thanks again
After updating Life360 to the latest release (2.9.5) I upgraded Home Assistant to 0.92.1 and Life360 is working fine.
Thanks for the great work Phil.
Phil
Followed your advice and took the plunge to 0.92.1
Everything is working OK now
I had, obviously, upgraded life360 to last release ( 2.9.5 ?) before upgrading
Well done, an thanks!
Javier
Iām only getting the device tracker as a state it does not appear to register as an entity under Entity Registry. Is this expected or did I miss something?
Ideally Iād like to use the status in node-RED to trigger various flows, but node-RED required the Entity_ID.
Iām using hassio if that helps.
That is normal. That is how device_trackerās currently work. What you see on the States page is an entity_id. I.e., device_tracker.xxx
is an entity_id.
Hello all.
Im a bit stuck with the updating life360 device tracket for home assistant.
I installed it manually a couple of months back.
I have updated home assistant to 0.92 to look at some of the ESP camera functions that DrZzs is playing with.
The Life360 stopped working, so I commented out the config.yaml to park it for a while. I am now trying to fix it but I cant even get the error message up again as I cant upload āerrorsā in the config.yaml
Can you please tell me the best steps to follow. I think I go distracted by custom updater and that failedā¦
Just want to re install life360 from scratch.
Sorry for the bone questions, a point in the right direction would be appreciated.
Regards, Rob
Hi Phil
I cannot seem to get Life360 to show the Entity and badge on overview screen. I am sure I have setup as per you detailed description however it is not showing my User under states
I have a feeling reading these posts that it relates to where my config folder is located. I setup Home assistant on Pi 3 B+ and it is working fine for all my devices thus far.
I have tried Owntrack which was ok and now I would like to run with Life360.
Reading this post my Configuration.yaml file is located here
Path to configuration.yaml: /config
If I go to the home /homeā¦ this folder is empty and has been empty since my install
I do not have the following path as per this post
/home/homeassistant/.homeassistant/custom_components
I have created the custom_components folder under
/config/custom_components, which is the same location as the configuration.yaml file
I am assuming this is partly to do with my issues? I hope this all makes sense to you
Also, it appears I have loaded your version 2.9.5
Really hope you can help as I really keen on running your project
cheers
This seems correct for your install. You should, therefore, have at least these files:
/config/custom_components/life360/__init__.py
/config/custom_components/life360/device_tracker.py
/config/custom_components/life360/manifest.json
Also good.
What version of HA do you have?
Do you see any messages at all in the log about life360? Either on the Info page, or more importantly, in home-assistant.log? Do you have logger set to debug?
What do you see in /config/known_devices.yaml
Thanks for your reply.
Yes i do have the 3 files located in custome_components/life360 folder
I am running HA version 0.91.4 (See attached)
There is four messages in the Info Page
a - Suppressing further errors until OK: get_circles: HTTPError: 502 Server Error: Bad Gateway for url: https://api.life360.com/v3/circles.json
8:28 AM custom_components/life360/device_tracker.py (ERROR)
b. - get_circles: HTTPError: 502 Server Error: Bad Gateway for url: https://api.life360.com/v3/circles.json
c. - get_circles: ReadTimeout: HTTPSConnectionPool(host=āapi.life360.comā, port=443): Read timed out. (read timeout=9.0)
8:28 AM custom_components/life360/device_tracker.py (WARNING)
d. - You are using a custom component for life360.device_tracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
8:17 AM loader.py (WARNING)
e. You are using a custom component for life360 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
- I have just turned on Logging have attached the log
Not sure how to upload Log file to you, so here is google drive. Hope it works
Thanks in advance for your help
Sorry fogot Known devices
My new one for Life360 is called āBruceā and it is not showing in Know devices.yaml file
bruces_xs:
hide_if_away: false
icon:
mac:
picture: /local/brucys_small.png
track: true
bruce_ipad_pro:
hide_if_away: false
icon:
mac:
name: Bruce iPad Pro
picture:
track: true
jessicaās iPhone:
hide_if_away: false
icon:
mac:
picture: /local/jess.jpg
track: true
hildaās iPhone (2):
hide_if_away: false
icon:
mac:
picture: /local/hilda.jpg
track: true
hildas_iphone_2:
hide_if_away: false
icon:
mac:
name: Hildaās iPhone (2)
picture:
track: true
You donāt have logger set to debug, so I canāt see what life360 may or may not be doing. Please try something like this:
logger:
default: info
logs:
custom_components.life360: debug
life360: debug
Also, can you share your life360 configuration (redacting anything sensitive)?
ok I have added Debug for Life360
Here is extract of log for that pertains to Life360.
Hope this what you are looking for
Cheers
2019-05-01 09:21:58 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 2.4 seconds.
2019-05-01 09:21:58 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 3.3 seconds.
2019-05-01 09:21:58 INFO (MainThread) [homeassistant.setup] Setting up history
2019-05-01 09:21:58 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-05-01 09:21:58 INFO (MainThread) [homeassistant.loader] Loaded life360 from custom_components.life360
2019-05-01 09:21:58 WARNING (MainThread) [homeassistant.loader] You are using a custom component for life360 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-05-01 09:21:58 INFO (MainThread) [homeassistant.loader] Loaded life360.device_tracker from custom_components.life360.device_tracker
2019-05-01 09:21:58 WARNING (MainThread) [homeassistant.loader] You are using a custom component for life360.device_tracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-05-01 09:21:58 INFO (MainThread) [homeassistant.loader] Loaded mqtt.switch from homeassistant.components.mqtt.switch
2019-05-01 09:22:02 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 2.5 seconds.
2019-05-01 09:22:02 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.5 seconds.
2019-05-01 09:22:02 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 3.1 seconds.
2019-05-01 09:22:03 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 3.3 seconds.
2019-05-01 09:22:03 DEBUG (SyncWorker_0) [custom_components.life360.device_tracker] Checking Places
2019-05-01 09:22:03 INFO (SyncWorker_10) [homeassistant.components.plex.media_player] Discovery configuration done (no token needed)
2019-05-01 09:22:03 INFO (SyncWorker_10) [homeassistant.components.plex.media_player] Connected to: http://192.168.1.200:32400
2019-05-01 09:22:03 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 1.5 seconds.
2019-05-01 09:22:04 DEBUG (SyncWorker_0) [custom_components.life360.device_tracker] Will check Places every: 0:15:00
2019-05-01 09:22:05 DEBUG (SyncWorker_0) [custom_components.life360.device_tracker] Setup successful!
2019-05-01 09:22:05 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 5.1 seconds.
2019-05-01 09:22:05 INFO (MainThread) [homeassistant.loader] Loaded owntracks.device_tracker from homeassistant.components.owntracks.device_tracker
2019-05-01 09:22:05 INFO (MainThread) [homeassistant.setup] Setting up ios
2019-05-01 09:22:05 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2019-05-01 09:22:05 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.owntracks
