Life360 Device Tracker Platform
Phil,
I currently have my configs like you showed in the migration with the files in the life360 folder under custom_components. I have the following as below:
life360:
accounts:
- username: !secret life360_username
password: !secret life360_password
driving_speed: 18
interval_seconds: 10
max_gps_accuracy: 100
max_update_wait:
minutes: 45
prefix: life360
show_as_state:
- driving
- moving
warning_threshold: 2
error_threshold: 3
I removed it from device_tracker. The question I have is I see a lot of people doing templates that pull battery information, location, etc but not sure how they are getting that from this setup. If I add any of these states it fails on ā€œcheck configā€ (places) it seems to only like driving, moving only.
Please see:
This does not show that places is an option for show_as_state. Also the migration instructions specifically state that places is no longer supported.
Also, there shouldnā€™t be any life360 related files under custom_components.
So you do not need the Life360 custom_components files anymore? Cool. That is what I thought on ā€œplacesā€ but I did not see that line in the instructions. Ah I see what I was doing wrong nowā€¦ ā€œread the freakin manualā€ duhā€¦thanks
Step 1 in the migration instructions is to delete them. All the files are now part of the standard HA release.
Hi
I removed from my phone the life 360 app, anb deleted it also from configuration.yaml. I also delete it from known_devices. However when I restart HA my details keeps appear in known_devices and I have the sensors also in the fronted. How can I completely remove it please?
Go to the Integrations page, click on Life 360, then click the delete button. Then remove the entries from known_devices.yaml again. When you restart HA they should be gone.
Anyone else having lots of issues with life360 updates today? My logs are more full than usual with bad gateway, max retries exceeded, etc.
Iā€™ve seen more than usual as well. Still working, though.
Yes, just walked into a dark house which is out of the ordinaryā€¦and then took several more minutes to finally get connected. I wonder if Life360 is limiting resources to non-app sourced requestsā€¦
No Issues hereā€¦ depending on your setup you may want to leverage a second source for device tracking for the automations you run when you get home. I am using WiFi peering to trigger several automations with a ton of success lately.
Itā€™s nothing to do with the app sourcing - their website is also barely working at the moment.
On another unrelated but sort of related note, Iā€™m STILL having issues with their app going dark (not reporting location) inexplicably for spans of time and then suddenly inexplicably starting to work again. These can last for a few hours to a day or so. Unrelated to battery percentage. Started to happen about 6-8 months ago. I posted about it at the time.
Life360 just posted a notification on the appā€¦they are working on things.
Iā€™m not getting a device tracker for Life360ā€¦ what am I missing?
Just added the integration Life360, entered my username and password. When I click on the integration name it says ā€˜this integration does not have any devicesā€™. I have been patient for a couple of days, also rebooted twice in that period. But still ā€˜no devicesā€™.
The Life360 app is installed on my phone, location sharing is activated, I can see my position in the app.
What more do I need to do to get a device tracker in Home Assistant?
That is normal.
Do you see any device_tracker entities (try looking on the States page)? What is in known_devices.yaml? Do you have any life360 configuration entries, and if so, what? Did you previously use the custom integration?
No device tracker for Life360 in the States page. Thereā€™s no configuration entries for Life360. I did not previously use the custom integration. In known_devices.yaml at the bottom I found this:
life360_roelof:
  hide_if_away: false
  icon:
  mac:
  picture:
  track: false
I just set track: true. Thatā€™s probably it :slight_smile: Is it normal that it defaults to track: false? If so, shouldnā€™t we mention it in the docs?
You probably have ā€œtrack_new_devices: falseā€ somewhere in your config under ā€œdevice_tracker: new_device_defaults:ā€. And this is mentioned in the docs. Unfortunately what people tend to forget, or maybe not appreciate fully, is that this is a global device tracker configuration.
Interesting. Indeed I have track_new_devices: false set under the first configured device_tracker which is asuswrt. Apparently you are right, this is a global setting. I think this is not very clearly described in the Device Tracker docs page, could be improved. Also, a link from the Life360 docs page to the device tracker page might clarify things a little. Iā€™ll post a PR for the docs on Github.
Edit: done :slight_smile:
Thank you for your work with this, Phil. Iā€™m wondering what best practices would be for presence detection. Looks like for the most part I go from ā€˜homeā€™ to ā€˜drivingā€™ so would a good automation be to use those two states to determine that Iā€™m away? Iā€™m asking because I realize Iā€™m not levering the not_home state that I see mentioned so want to ensure I have set this up correct (still learning HA & automations :slight_smile: )
Hi. I just saw your post on discord, too.
To trigger an automation with a state trigger you do not have to specify both from: and to:. In this case you can just use from: home. That will trigger whenever you leave.
Also, if you donā€™t like, or otherwise donā€™t want your device tracker to have the driving and/or moving states, then just change your life360 configuration accordingly.
Great point about using only the from field. Disappointed I didnā€™t think of thatā€¦kind of obvious. Thank you for taking it easy on the n00b!
