Update to the life360 package has been released. As an interim fix (i.e., before a HA release that updates to it), if you are using a container install, and you know how to get to a command line, you can do:
cd /usr/src/homeassistant/homeassistant/components/life360/
sed -i "s/6.0.0/6.0.1/" manifest.json
hmmm, I ran the commands successfully and restarted HA, however I am still getting invalid authentication. Anyone else still seeing this? Iām on HA 12.3
About #3 - HA own application: we have 2 iPhones at home - my wifeās and mine.
My HA tracker shows all needed information (18 entities) and very stable, including BSSID and SSID information, my wife phone shows only 12 entities and often location is unavailable (especially if her phone is locked).
Her BSSID and SSID is never connected. So, Life360 was 2nd layer of redundancy
I still canāt figure out whatās wrong with her phone - needless to say she is not very enthusiastic to let me dive in her phone settings
this is great @pnbruckner! Amazing you were able to find a fix! is there a way to deploy the fix in Home Assistant OS, or just be patient and wait until it is merged?
Any word on how to apply this fix to HAOS? I now we used to do this stuff with MyQ all the time, but messing around last night trying to modify things myself, I had no luck.
Iām struggling with this, clearly doing something wrong
iāve got Home Assistant installed on proxmox
if I go to the proxmox shell it says
"root@pve:~# cd /usr/src/homeassistant/homeassistant/components/life360/
-bash: cd: /usr/src/homeassistant/homeassistant/components/life360/: No such file or directory
root@pve:~# "
This worked for me too with HAOS. Thanks for the heads up! From the look of things, a few may have to reset password if they made a lot of failed attempts after copying the file, rebooting, and trying again.
At the prompt type login and hit enter to get a linux shell.
Type docker exec -it homeassistant /bin/bash to get into the bash shell of the home assistant container. cd /usr/src/homeassistant/homeassistant/components/life360/
run the sed command. exit twice
restart home assistant.
EDIT:
Confirmed working on HAOS
Thanks @pnbruckner
If you mean you have a Python even install, then just go to wherever homeassistant is located, look for components/life360/manifest.json, and edit that file to change the version of the life360 package from 6.0.0 to 6.0.1.
This workaround is not working for me. Iām consistantly getting āInvalid authenticationā in the integration when I try to auth in. I am running in a docker container.
I have tried:
Running the sed command in the container with a restart of HA, reboot of the container, reboot of the machine.
Replacing api.py in the container with a restart of HA, reboot of the container, reboot of the machine.
Deleting the integration and reinstalling it, once again trying #1 and #2 above.
