So I thought it would be a good idea to upgrade multiple major versions without really reading the breaking changes, real smart I know. I upgraded from 0.77.3 to 0.82.1 and now have a few issues with my Home Assistant. My main one at the moment is LIFX bulbs aren’t showing up.
I noticed that LIFX has been moved to the integrations set up. So I commented out:
light:
# - platform: lifx
And went to set up via web gui, a separate window pops up asking: Do you want to set up LIFX?
I hit submit button and receive an: “Unknown error occurred”
tail -f /home/homeassistant/.homeassistant/home-assistant.log
2018-11-28 14:21:06 ERROR (MainThread) [aiohttp.server] Error handling request
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 390, in start
resp = await self._request_handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_app.py", line 366, in _handle
resp = await handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_middlewares.py", line 106, in impl
return await handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/view.py", line 113, in handle
result = await result
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/data_validator.py", line 47, in wrapper
result = await method(view, request, *args, **kwargs)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/data_entry_flow.py", line 86, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/data_entry_flow.py", line 80, in async_configure
flow, step_id, user_input)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/data_entry_flow.py", line 98, in _async_handle_step
result = await getattr(flow, method)(user_input) # type: Dict
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/config_entry_flow.py", line 62, in async_step_confirm
self._discovery_function, self.hass)
File "/usr/local/lib/python3.5/asyncio/futures.py", line 381, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/local/lib/python3.5/asyncio/tasks.py", line 310, in _wakeup
future.result()
File "/usr/local/lib/python3.5/asyncio/futures.py", line 294, in result
raise self._exception
File "/usr/local/lib/python3.5/asyncio/tasks.py", line 240, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/lifx/__init__.py", line 53, in _async_has_devices
lifx_ip_addresses = await aiolifx.LifxScan(hass.loop).scan()
File "/srv/homeassistant/lib/python3.5/site-packages/aiolifx/aiolifx.py", line 1281, in scan
(done, pending) = await aio.wait(tasks, timeout=1)
File "/usr/local/lib/python3.5/asyncio/tasks.py", line 352, in wait
raise ValueError('Set of coroutines/Futures is empty.')
ValueError: Set of coroutines/Futures is empty.
