Did it support vivi ZLight HaiPaiTech? I only got “color loop” in effects list.
Does this work with lovelace-auto-entities?
its the last bit I need to have a complete dynamic UI, but I cannot get it to work
Hello, I am trying this plugin, but if I add a card, it only shows the name, no controls, no RGB-wheel or anything, must the controlled light have any special settings? It is identified as a RGB-light (see yaml for the light under)
- channel: 1
type: rgb
#default_rgb: [0,0,0]
transition: 3
Hey,
I’m new to HA and I wanted to try a frontend for the first time.
But when I entered the standard code into the custom card I got this.
Is there a way to fix this?
Thanks.
Did you install the custom card from HACS first?
I have a fibaro RGBW installed and manage to made this card and color picker wheel work.
What I don’t understand is the effect_list.
I see things come by with Rainbow, colorloop, Fireplace, LAPD etc. but how to get those effects so I can use them?
The effect list I can make visible but of course nothing worked when set a value as rainbow or colorloop, random.
Hi!
I have the light-entity-card installed, and it works fine for me. But every time, I switch on an light, I get a short error message:
What can I do, to avoid that error?
Thanks!
I had the same problem - light-entity-card
installed successfully through HACS, but when I tried to use it by manual entry it would show the same error. Restarting HA container helped, and light-entity-card
started appearing in card select, and I was also able to use it with manual entry.
Hi @emjay276 ,
I tried your approach to add the nice gradient background to my colour temperature slider. But unfortunately, I can’t get it to work.
What I did:
- I installed lovelace-card-mod via HACS:
- I added the following in configuration.yaml:
frontend:
themes: !include themes.yaml
# While card-mod can be installed as a lovelace resource, some functionality will benefit greatly from it being installed as a frontend module instead.
# https://github.com/thomasloven/lovelace-card-mod
extra_module_url:
- /www/community/lovelace-card-mod/card-mod.js
themes.yaml contains nothing but:
default:
# Nice BG for color temperature slider
ha-slider-background-light-entity: 'linear-gradient(90deg, rgba(165,201,241,1) 0%, rgba(255,255,255,1) 50%, rgba(254,151,7,1) 100%)'
And my card has the following config:
type: custom:light-entity-card
entity: light.praktijkruimte_led_panelen
show_slider_percent: true
header: Paneelverlichting
brightness: true
color_temp: true
shorten_cards: true
consolidate_entities: true
child_card: false
full_width_sliders: true
hide_header: false
brightness_icon: weather-sunny
temperature_icon: thermometer
color_wheel: false
persist_features: false
white_value: false
color_picker: false
smooth_color_wheel: false
speed: false
intensity: false
force_features: false
white_icon: file-word-box
speed_icon: speedometer
intensity_icon: transit-connection-horizontal
style: |
.ha-slider-full-width ha-slider {
border-radius: 4px;
margin-left: 10px;
margin-right: 10px;
I have reloaded the themes and also rebooted Home Assistant.
But I don’t get the nice background.
I must admit, I’m relatively new to HA, so I probably overlooked something?
Is there anyone that can help me with the above? I would really like to have a color temperature background for my slider.
Hi
I wasn’t able to find this Issue in this Topic.
When i have persist_features=true
i have the bug that the Light can’t be switched off , even through the Card’s own switch. If i turn persist_features
off, the Switch works normal again and the light can be switched on and of. I use the Version 5 of the Card Addon
I’m Using a Light group entity
My Card config is as followed:
shorten_cards: false
child_card: false
hide_header: false
header: Pc Licht
color_wheel: true
persist_features: true
brightness: true
color_temp: true
white_value: true
color_picker: true
speed: false
intensity: true
entity: light.pc_licht
effects_list: true
Is this a known bug? And if yes, what’s the solution to it?
Anyone has an idea how I can add an mdi: icon to the header field on this card?
I already tried adding this to my card code but this does not work:
<ha-icon icon=“mdi:mdi:ceiling-light-outline”>
Also adding the code below does nothing:
icon: mdi:ceiling-light
thanks, did not think about this, let me dig in.
Hey, mine is also currently broken. I also switched to mushroom cards.
If I have some time, I will try to fix it for you.
I’m having an issue and I just wanted to check if this is normal behaviour.
I use several Light Entity Cards on a Lovelace dashboard and whenever I switch to that dashboard view all the lights revert to the settings when that page was last viewed, rather than it reading the status of each light and setting the view accordingly.
So, for example:
- I turn a group of bulbs on using the card
- I navigate to somewhere else in Home Assistant
- An automation turns the bulbs off
- I go back to the dashboard with the light card on and the bulbs get turned back on again
Is this normal? It doesn’t happen with other cards - like my heaters, for example.
I should mention that I have groups with several bulbs in, but I’ve not tested this with individual bulbs (I will do that and report back).
Hello, I don’t know how to merge a group of lights under the same color wheel, I think I did it correctly but I guess I did not.
I made a helper that has both of my lights. Then I made a Light Entity Card and selected the new helper entity, however it displays two color wheels (one for each device in the group) rather than one to control both.
I tried using group: true
but it is apparently not doing anything. How can I use one single color wheel for two entities? Thanks.
Do you have persist_features
enabled?
If yes: try to disable it and try again.
I have the issue that persist_features
would switch my lights back on if i switch them of through the UI
Yes, I did originally and did try that but it didn’t fix it. Unless it needs to be disabled for all cards in the same view. I didn’t try that.
