Hi! This might sound like a stupid question but I would like to give it a shot. Is it possible to use the color wheel on a dumb LED strip? I have an LED strip that changes its color through IR. I am using Broadlink to control it in HA. TIA!
When I consolidate entities I donāt get a color wheel. Is this normal behaviour?
I wanted to use the card to switch multiple RGBW strips to the same color at the same time.
Without consolidate entities, the wheel works for all entities
Consolidated: the wheel also doesnāt show when turning it on.
First-time HA user, here. Iām trying to use light-entity-card to control an Ikea TrĆ„dfri RGB light through Zigbee2MQTT. At first, the card wouldnāt load, but that got fixed with 2021.1.3.
However, it wonāt display the color wheel even though this is an RGB bulb. Or the effects list for that matter.
Here is the relevant part of my my ui-lovelace.yamlā¦
cards:
- type: custom:light-entity-card
entity: light.man_cave_light
persist_features: true
color_picker: true
effects_list: input_select.custom_effect_list
Here is the relevant part of my configuration.yamlā¦
lovelace:
mode: yaml
resources:
- url: /hacsfiles/light-entity-card/light-entity-card.js
type: module
Here is what Iām seeing in my Overviewā¦
Interestingly, when I am using Configuration > Scenes to create a scene with this bulb, I get a color picker that looks an awful lot like light-entity-card. I was going to post an image of it, but apparently new users are limited to one image per post.
Thanks for the help,
Don
Hi and thanks for this card. Iām using it with a Monoprice Goodway RGB/W (looks like the Qubino) controller and RGBW strip lights. When I first installed HA and Z-Wave, it found this device and put an RGB picker in my default dashboard. Somehow, I lost that and re-adding the device only gave me 2 dimmers, no RGB picker. So I tried your card and while it works, when I pick a color it seems to swim across the other colors between the 2. As I recall, the one that HA choose for it allowed a direct pick of a color. Any suggestions? Thanks again.
Just following up to my posts of last week. Iāve updated HA to 2021.1.5 and HACS to 1.10.1 and the card is now working fine after reinstalling.
I have tried this card briefly but cannot understand how to use it with the pre-defined programs in my RGBW controller (effect list)
The effect is triggered by setting a parameter on the z-wave device like
service: zwave.set_config_parameter
data_template: {
"node_id": 7,
"parameter": 72,
"value": <the-individual-value-per-button>,
Does anyone have an example on how to do this with this card?
Need some help here.
I have created an input_select as:
albin_rgbw:
options:
- None
- Fireplace
- Storm
- Rainbow
- Aurora
- LAPD
initial: None
I have automations setup:
- alias: RGBW Effect Off
platform: state
entity_id: input_select.albin_rgbw
to: "None"
data_template: {
"node_id": 7,
"parameter": 72,
"value": 1
- alias: RGBW Fireplace
platform: state
to: "Fireplace"
data_template: {
"node_id": 7,
"parameter": 72,
"value": 6
- alias: RGBW Storm
platform: state
to: "Storm"
data_template: {
"node_id": 7,
"parameter": 72,
"value": 7
- alias: RGBW Rainbow
platform: state
to: "Rainbow"
data_template: {
"node_id": 7,
"parameter": 72,
"value": 8
- alias: RGBW Aurora
platform: state
to: "Aurora"
data_template: {
"node_id": 7,
"parameter": 72,
"value": 9
- alias: RGBW LAPD
platform: state
to: "LAPD"
data_template: {
"node_id": 7,
"parameter": 72,
"value": 10
And finally the Lovelace card as:
title: Albin
- badges: []
cards:
- type: 'custom:light-entity-card'
entity: light.albin_rgbw_level_6
effects_list: input_select.albin_rgbw
path: albin
title: Albin
When running the automations directly = they works as expected
When tiggering via light-entity-card = it doesnāt work.
Do you have any ideas?
Hi!
Iām having a similar issue. I also have a working input_select. However, when I try to use it via this card it triggers the light on command and not at all the input_select options. I can see this from the logs as an error/warning ālight already onā.
Any help is much appreciated.
@Foguli I created a separate entity which works perfect
- type: entities
entities:
- entity: input_select.albin_rgbw
title: Ljuseffekt
state_color: false
Thanks! That works much better than just an entity card. Iād still like to get the embedded effect list to work somedayā¦
I have the exact same issue, did you figure out how to get a color wheel with consolidate option true?
Sadly no, I still havenāt found a solution for this.
Another heads-up from other thread that could affect this: Controlling Fibaro RGBW via REST API
On the android app i have to tap to select color. is there any way to enable holding down my finger and letting HA update the colors on the fly?
it gets a bit tedious when i wana select the colors all the way at the edges, but i keep pressing just outside the circle.
would be nice if i could press in the middle then drag to the desired color.
Iām having the same issue. Did you get this fixed?
Anyone else having the issue with this card where config.yaml defined light groups no longer show controls like brightness, color, etc? All I can do in my interface is toggle the switch on and off, but I get no controls in lovelace for brightness or anything else. The brightness controls show up in the entities themselves, but not in this card.
EDIT: Looks like itās the same issue everyone else is having re: consolidated entitiesā¦
Good afternoon, there are no such problems.
but the lack of an icon and a different font throws me off balance. How can this be corrected?
code:
type: entities
entities:
- entity: sensor.gateway_uptime
- entity: switch.gateway_join
entity: light.gateway_led
shorten_cards: true
brightness: true
color_temp: true
white_value: false
color_picker: true
smooth_color_wheel: false
hide_header: false
child_card: true
show_slider_percent: true
full_width_sliders: true
brightness_icon: weather-sunny
white_icon: file-word-box
temperature_icon: thermometer
effects_list: false
group: false
title: SLS Gateway
show_header_toggle: false
I thing there is an error in the HA. i always used the original RGB card with my Athom RGBWW. since a few days the card works not fine. the color temp doesnt work. changing from white to any color by tapping in the colorwheel does nothing. of course this i went to this RGB card.
I noticed the same issue and was bummed. I like this card, because I can hide everything and JUST have a brightness slider under a larger ābuttonā. It works well in a dashboard setup. Hoping this gets fixed in a future update. It used to work great with light groups.
