@ASNNetworks Can you give me a hint how you installed it? I can’t find it in HACS currently.
It was in HACS for me. You are adding it with the plus sign right? I notice people don’t always use HACS correct and use the search bar instead, which only shows stuff that’s new or already installed.
stupid me, Missed the Orange “+” button in the corner and tried to search in the top Search field. All sorted, thanks anyway,
Yes, that’s what I said But you figured that out as well and posted that right after I did.
Still a newbie to home assistant. I’ve managed to install the card and display it, and turn on/off lights using it, but I’m struggling to get the color picker to show! Is this working for others?
Did you set color_picker: true
in your card config?
I did. I guess it works for you then
Yes, with HA 108.4.
I’m using this Custom Card for Fibaro RGBWM441 Zwave controllers, and notice that when the lights are off, the card displays in Lovelace as:
But when the lights are on, I see:
Is this expected behaviour?
I’m using Version 0.118.4 on HassOS 5.5
Read the ReadMe of the component.
Use persist_features: true
Aha - thank you.
Thanks for the card.
It works great, but when I select an effect I get this error in Home Assistant:
Scene ‘’ not in scene list.
But the effect is going to my Wiz Light so it works.
Any idea how I can get rid of this error ?
Regards,
Bart
Anyone aware if there’s a an option for -name: xxxxx to use an alternate name than the underlying entity name?
Isn’t that just the header
setting?
Not that I’ve seen? Here’s my current card:
Here’s the config:
So really trying to drop the ‘Room’ from the name, and not use the ‘Friendly Name’, but this name as overwritten ui-lovelace.yaml:
set consolidate_entities
to true. i really want to rewrite that whole header code but it would be a breaking change…
I just renamed the underlying entity in HA. Looked and saw I really don’t ‘use’ that friendly name anywhere else (this is one of the only places that can’t use the name: override), so no big deal. Certainly not trying to put more work / breaking changes on anyone!! Love the card and grateful for your work on it!
Hey everyone
I was wondering if there is a way of always showing the color wheel even when the lights are off
Since I am here, what about changing the placing of the white or brightness sliders. For example to the bottom.
I would really love to always have the card with the same size and features even if the light is off. This way I can start specifically where I want instead of starting in my last point and then change
I already asked about persisting the color wheel further up in the thread, and got the answer:
Oh, much appreciated, I must have missed it
For some reason I had this coded to false, but don’t recall reading it
