Light integration using 3 knx group addresses (one each channel)
Hi all,
I run HA with KNX integration. Via KNX I can control some leds by submitting RGB values using 3 group addresses:
e.g.:
         - service: knx.send
            #red
             address: "5/3/30"
             payload: "100"
             type: "percent"
         - service: knx.send
            #green
             address: "5/3/31"
             payload: "50"
             type: "percent"
         - service: knx.send
            #blue
             address: "5/3/32"
             payload: "0"
             type: "percent"
Do you have any hints, how to make this accessible as a light in HA? I tried light template already (see below) but unfortuneatly only with very limited success:
    lights:
      myKnxLed:
        friendly_name: "My KNX LED"
#WORKS:
        turn_on:
          - service: knx.send
              address: 5/3/30
              payload: "100"
              type: "percent"
          - service: knx.send
              address: 5/3/31
              payload: "100"
              type: "percent"
          - service: knx.send
              address: 5/3/32
              payload: "100"
              type: "percent"
#WORKS:
        turn_off:
          - service: knx.send
              address: 5/3/30
              payload: "0"
              type: "percent"
          - service: knx.send
              address: 5/3/31
              payload: "0"
              type: "percent"
          - service: knx.send
              address: 5/3/32
              payload: "50"
              type: "percent"
#WORKS (obviously for brightness < 100), still WIP:
        set_level:
          - service: knx.send
              address: 5/3/30
              payload: "{{ brightness }}"
              type: "percent"
          - service: knx.send
              address: 5/3/31
              type: "percent"
          - service: knx.send
              address: 5/3/32
              type: "percent"
# NOT WORKING:
        set_color:
          - service: knx.send
              address: 5/3/30
              payload: "{{ r }}"
              type: "percent"
          - service: knx.send
              address: 5/3/31
              payload: "{{ g }}"
              type: "percent"
          - service: knx.send
              address: 5/3/32
              payload: "{{ b }}"
              type: "percent"
The KNX system is preinstalled and cannot be modified from my side. Any feedback appreciated.
Hi! Why don’t you use the KNX integrations Light platform and its individual_colors configuration?
… because I wasn’t aware of it… :see_no_evil:
Works like a charm! Thanks a lot for pointing me there :+1:
