Linear GD00z-4 Issues
Hello, over the weekend I had a garage sale and to keep people from trying to enter my garage, I opened the door just enough we could bend over and walk under it. This caused all sorts of problems with my GD00z-4 controller that I was unable to resolve. I ended up excluding it, resetting it, and then secure pairing it again, but now none of the entities appear after it pairs. What am I doing wrong? My ozw log is below from where I tried to refresh the entity. I am running Hass.io in a docker session on Ubuntu 18.04 with a HUSBZB-1 combo stick.
2019-11-12 16:56:10.682 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=ProtocolInfo live=1
2019-11-12 16:56:10.682 Detail, Node034, QueryStage_Probe
2019-11-12 16:56:10.682 Info, Node034, NoOperation::Set - Routing=true
2019-11-12 16:56:10.682 Detail, Node034, Queuing (NoOp) NoOperation_Set (Node=34): 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x00, 0x00, 0x25, 0x7a, 0x9a
2019-11-12 16:56:10.682 Detail, Node034, Queuing (Query) Query Stage Complete (Probe)
2019-11-12 16:56:10.683 Detail,
2019-11-12 16:56:10.683 Info, Node034, Sending (NoOp) message (Callback ID=0x7a, Expected Reply=0x13) - NoOperation_Set (Node=34): 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x00, 0x00, 0x25, 0x7a, 0x9a
2019-11-12 16:56:10.688 Detail, Node034,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-12 16:56:10.689 Detail, Node034,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-12 16:56:10.704 Detail, Node034,   Received: 0x01, 0x05, 0x00, 0x13, 0x7a, 0x00, 0x93
2019-11-12 16:56:10.704 Detail, Node034,   ZW_SEND_DATA Request with callback ID 0x7a received (expected 0x7a)
2019-11-12 16:56:10.704 Info, Node034, Request RTT 21 Average Request RTT 36
2019-11-12 16:56:10.704 Detail,   Expected callbackId was received
2019-11-12 16:56:10.704 Detail,   Expected reply was received
2019-11-12 16:56:10.704 Detail,   Message transaction complete
2019-11-12 16:56:10.704 Detail, Node034, Removing current message
2019-11-12 16:56:10.705 Detail, Node034, Notification: Notification - NoOperation
2019-11-12 16:56:10.711 Detail, Node034, Query Stage Complete (Probe)
2019-11-12 16:56:10.711 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=WakeUp live=1
2019-11-12 16:56:10.711 Detail, Node034, QueryStage_WakeUp
2019-11-12 16:56:10.711 Detail, Node034, QueryStage_ManufacturerSpecific1
2019-11-12 16:56:10.711 Detail, Node034, Checking for ManufacturerSpecific CC and Requesting values if present on this node
2019-11-12 16:56:10.711 Detail, Node034, Queuing (Query) ManufacturerSpecificCmd_Get (Node=34): 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x72, 0x04, 0x25, 0x7b, 0xed
2019-11-12 16:56:10.711 Detail, Node034, Queuing (Query) Query Stage Complete (ManufacturerSpecific1)
2019-11-12 16:56:10.711 Info, Node034, Sending (Query) message (Callback ID=0x7b, Expected Reply=0x04) - ManufacturerSpecificCmd_Get (Node=34): 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x72, 0x04, 0x25, 0x7b, 0xed
2019-11-12 16:56:10.717 Detail, Node034,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-12 16:56:10.717 Detail, Node034,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-12 16:56:10.733 Detail, Node034,   Received: 0x01, 0x05, 0x00, 0x13, 0x7b, 0x00, 0x92
2019-11-12 16:56:10.733 Detail, Node034,   ZW_SEND_DATA Request with callback ID 0x7b received (expected 0x7b)
2019-11-12 16:56:10.733 Info, Node034, Request RTT 21 Average Request RTT 28
2019-11-12 16:56:10.733 Detail,   Expected callbackId was received
2019-11-12 16:56:10.743 Detail, Node034,   Received: 0x01, 0x0e, 0x00, 0x04, 0x00, 0x22, 0x08, 0x72, 0x05, 0x01, 0x4f, 0x47, 0x44, 0x30, 0x30, 0xe5
2019-11-12 16:56:10.743 Info, Node034, Response RTT 32 Average Response RTT 32
2019-11-12 16:56:10.763 Info, Product name collision: FGR223 Roller Shutter Controller 3 type 303 id 1000 manufacturerid 10f, collides with FGRM223 Roller Shutter Controller 3, type 303 id 1000 manufacturerid 10f
2019-11-12 16:56:10.766 Info, Node034, Received manufacturer specific report from node 34: Manufacturer=Linear (Nortek Security Control LLC), Product=GD00Z-4 Garage Door Opener Remote Controller
2019-11-12 16:56:10.766 Info, Node034, Node Identity Codes: 014f:4744:3030
2019-11-12 16:56:10.766 Detail, Node034,   Expected reply and command class was received
2019-11-12 16:56:10.766 Detail, Node034,   Message transaction complete
2019-11-12 16:56:10.766 Detail, Node034, Removing current message
2019-11-12 16:56:10.767 Detail, Node034, Notification: NodeNaming
2019-11-12 16:56:10.769 Detail, Node034, Query Stage Complete (ManufacturerSpecific1)
2019-11-12 16:56:10.769 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=NodeInfo live=1
2019-11-12 16:56:10.769 Detail, Node034, QueryStage_NodePlusInfo
2019-11-12 16:56:10.769 Detail, Node034, QueryStage_SecurityReport
2019-11-12 16:56:10.769 Detail, Node034, Queuing (Security) SecurityCmd_SupportedGet (Node=34): 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x98, 0x02, 0x25, 0x7c, 0x06
2019-11-12 16:56:10.769 Detail, Node034, Queuing (Query) Query Stage Complete (SecurityReport)
2019-11-12 16:56:10.769 Info, Node034, Processing (Security) Nonce Request message (Callback ID=0x7c, Expected Reply=0x04)
2019-11-12 16:56:10.769 Info, Node034, Sending (Security) message (Callback ID=0x7c, Expected Reply=0x04) - Nonce_Get(SecurityCmd_SupportedGet) - 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x98, 0x40, 0x05, 0x02:
2019-11-12 16:56:10.774 Detail, Node034,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-12 16:56:10.774 Detail, Node034,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-12 16:56:10.790 Detail, Node034,   Received: 0x01, 0x05, 0x00, 0x13, 0x02, 0x00, 0xeb
2019-11-12 16:56:10.790 Detail, Node034,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2019-11-12 16:56:10.790 Info, Node034, Request RTT 20 Average Request RTT 24
2019-11-12 16:56:20.769 Error, Node034, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-12 16:56:20.770 Detail, Node034, Removing current message
2019-11-12 16:56:20.770 Detail, Node034, Notification: Notification - TimeOut
2019-11-12 16:56:20.774 Detail, Node034, Query Stage Complete (SecurityReport)
2019-11-12 16:56:20.774 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=ManufacturerSpecific2 live=1
2019-11-12 16:56:20.774 Detail, Node034, QueryStage_Versions
2019-11-12 16:56:20.774 Detail, Node034, QueryStage_Instances
2019-11-12 16:56:20.774 Info, Node034, Essential node queries are complete
2019-11-12 16:56:20.774 Detail, Node034, QueryStage_Static
2019-11-12 16:56:20.774 Detail, Node034, Queuing (Query) Query Stage Complete (Static)
2019-11-12 16:56:20.774 Detail, Node034, Notification: EssentialNodeQueriesComplete
2019-11-12 16:56:20.776 Detail, Node034, Query Stage Complete (Static)
2019-11-12 16:56:20.776 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2019-11-12 16:56:20.776 Detail, Node034, QueryStage_Associations
2019-11-12 16:56:20.776 Detail, Node034, QueryStage_Neighbors
2019-11-12 16:56:20.776 Detail, Requesting routing info (neighbor list) for Node 34
2019-11-12 16:56:20.776 Detail, Node034, Queuing (Command) Get Routing Info (Node=34): 0x01, 0x07, 0x00, 0x80, 0x22, 0x00, 0x00, 0x03, 0x59
2019-11-12 16:56:20.776 Detail, Node034, Queuing (Query) Query Stage Complete (Neighbors)
2019-11-12 16:56:20.776 Info, Node034, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=34): 0x01, 0x07, 0x00, 0x80, 0x22, 0x00, 0x00, 0x03, 0x59
2019-11-12 16:56:20.782 Detail, Node034,   Received: 0x01, 0x20, 0x01, 0x80, 0x07, 0xd6, 0xea, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x51
2019-11-12 16:56:20.782 Info, Node034, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2019-11-12 16:56:20.782 Info, Node034,     Neighbors of this node are:
2019-11-12 16:56:20.782 Info, Node034,     Node 1
2019-11-12 16:56:20.782 Info, Node034,     Node 2
2019-11-12 16:56:20.782 Info, Node034,     Node 3
2019-11-12 16:56:20.782 Info, Node034,     Node 10
2019-11-12 16:56:20.782 Info, Node034,     Node 11
2019-11-12 16:56:20.782 Info, Node034,     Node 13
2019-11-12 16:56:20.782 Info, Node034,     Node 15
2019-11-12 16:56:20.782 Info, Node034,     Node 16
2019-11-12 16:56:20.782 Info, Node034,     Node 18
2019-11-12 16:56:20.782 Info, Node034,     Node 20
2019-11-12 16:56:20.782 Info, Node034,     Node 22
2019-11-12 16:56:20.782 Info, Node034,     Node 23
2019-11-12 16:56:20.782 Info, Node034,     Node 24
2019-11-12 16:56:20.782 Info, Node034,     Node 27
2019-11-12 16:56:20.782 Info, Node034,     Node 29
2019-11-12 16:56:20.782 Info, Node034,     Node 30
2019-11-12 16:56:20.782 Detail, Node214,   Expected reply was received
2019-11-12 16:56:20.782 Detail, Node214,   Message transaction complete
2019-11-12 16:56:20.782 Detail, Node034, Removing current message
2019-11-12 16:56:20.782 Detail, Node034, Query Stage Complete (Neighbors)
2019-11-12 16:56:20.782 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2019-11-12 16:56:20.782 Detail, Node034, QueryStage_Session
2019-11-12 16:56:20.782 Detail, Node034, Queuing (Query) Query Stage Complete (Session)
2019-11-12 16:56:20.782 Detail, Node034, Query Stage Complete (Session)
2019-11-12 16:56:20.782 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2019-11-12 16:56:20.782 Detail, Node034, QueryStage_Dynamic
2019-11-12 16:56:20.782 Detail, Node034, Queuing (Send) BasicCmd_Get (Node=34): 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x20, 0x02, 0x25, 0x7d, 0xbf
2019-11-12 16:56:20.782 Detail, Node034, Queuing (Query) Query Stage Complete (Dynamic)
2019-11-12 16:56:20.782 Info, Node034, Sending (Send) message (Callback ID=0x7d, Expected Reply=0x04) - BasicCmd_Get (Node=34): 0x01, 0x09, 0x00, 0x13, 0x22, 0x02, 0x20, 0x02, 0x25, 0x7d, 0xbf
2019-11-12 16:56:20.788 Detail, Node034,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-11-12 16:56:20.788 Detail, Node034,   ZW_SEND_DATA delivered to Z-Wave stack
2019-11-12 16:56:20.804 Detail, Node034,   Received: 0x01, 0x05, 0x00, 0x13, 0x7d, 0x00, 0x94
2019-11-12 16:56:20.804 Detail, Node034,   ZW_SEND_DATA Request with callback ID 0x7d received (expected 0x7d)
2019-11-12 16:56:20.804 Info, Node034, Request RTT 21 Average Request RTT 22
2019-11-12 16:56:20.804 Detail,   Expected callbackId was received
2019-11-12 16:56:21.831 Detail, Node024, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2019-11-12 16:56:21.831 Detail, Node024, Queuing (Poll) SwitchBinaryCmd_Get (Node=24): 0x01, 0x09, 0x00, 0x13, 0x18, 0x02, 0x25, 0x02, 0x25, 0x7e, 0x83
2019-11-12 16:56:30.783 Error, Node034, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-11-12 16:56:30.783 Detail, Node034, Removing current message
2019-11-12 16:56:30.783 Detail, Node034, Notification: Notification - TimeOut
2019-11-12 16:56:30.788 Detail, Node034, Query Stage Complete (Dynamic)
2019-11-12 16:56:30.788 Detail, Node034, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2019-11-12 16:56:30.788 Detail, Node034, QueryStage_Configuration
2019-11-12 16:56:30.788 Detail, Node034, QueryStage_Complete
2019-11-12 16:56:30.788 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
2019-11-12 16:56:30.789 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2019-11-12 16:56:30.789 Detail, Node034, Notification: NodeQueriesComplete
So it’s kind of a long thread… but a good first
Step would be to also make sure your tilt sensor is still paired… press and hold reset button for about 8 seconds until it beeps then manually cycle door up and down (or hold in hand and tip few times with tamper switch held down) … then maybe proceed to read the steps from where I linked on… ultimately I somehow got the wrong version of openzwave installed. Someone else may be better at deciphering the ozw log to know for sure…
Here this seems more like your issue based on log Question about "Product name collision" in z-wave log
