Linear NGDZ00-4 Garage Door
If you’re running the new OpenZwave beta integration here’s an MQTT cover to help while they finish up cover support, just make sure you adjust your ValueIDKey to whatever the value is under .../commandclass/102/:
cover:
  - platform: mqtt
    device_class: garage
    command_topic: "OpenZWave/1/command/setvalue/"
    state_topic: "OpenZWave/1/node/6/instance/1/commandclass/102/value/281475083239444/"
    qos: 0
    retain: true
    payload_open: '{"ValueIDKey" : 281475083239444, "Value": 4}'
    payload_close: '{"ValueIDKey" : 281475083239444, "Value": 0}'
    state_open: "Opened"
    state_opening: "Opening"
    state_closed: "Closed"
    state_closing: "Closing"
    optimistic: false
    value_template: "{{ value_json.Value.Selected }}"
