Give this one a shot it should complete the required steps to get your OZW_Log.txt showing version 1.5.xxxx
#!/bin/bash
echo
echo "Open Z-Wave Installer for Hassbian"
echo "Modified by Landrash for use with Hassbian."
echo "Remodified by unt1tled for use with Linear NGDZ00-4 (barrier_operator)."
echo "Remodified again by firstof9 for use with the dev branch of the OpenZwave Library."
echo "Copyright(c) 2016 Dale Higgs <https://gitter.im/dale3h>"
echo
if [ "$(id -u)" != "0" ]; then
echo "This script must be run with sudo. Use \"sudo ${0} ${*}\"" 1>&2
exit 1
fi
echo "Running apt-get preparation"
apt-get update
apt-get upgrade -y
apt-get install -y make python3-dev libudev-dev python3-sphinx python3-setuptools libgnutlsxx28 libgnutls28-dev libssl-dev
echo "Changing to homeassistant user"
sudo -u homeassistant -H /bin/bash <<EOF
echo "Activating virtualenv"
source /srv/homeassistant/homeassistant_venv/bin/activate
echo "Installing latest version of cython"
### Currently locked to this version since build fails for later versions.
pip3 install --upgrade cython==0.24.1
echo "Removing old python-openzwave"
pip3 uninstall -y python-openzwave
rm -f /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/libopenzwave.cpython-34m.so
echo "Creating source directory"
mkdir -p /srv/homeassistant/src
chown -R homeassistant:homeassistant /srv/homeassistant/src
echo "Cloning python-openzwave"
cd /srv/homeassistant/src
git clone https://github.com/OpenZWave/python-openzwave.git
chown homeassistant:homeassistant python-openzwave
cd python-openzwave
echo "Cloning openzwave"
git checkout python3
rm -rf openzwave
git clone git://github.com/OpenZWave/open-zwave.git openzwave
cd openzwave
echo "Changing to openzwave Dev branch to add barrier_operator support"
git checkout Dev
cd ..
#echo "Replacing openzwave source files to add barrier_operator support"
#wget -O openzwave/config/device_classes.xml https://raw.githubusercontent.com/OpenZWave/open-zwave/c808b7431fb6c28b408e7fdc5492e46420cb6926/config/device_classes.xml
#wget -O openzwave/cpp/src/command_classes/BarrierOperator.cpp https://raw.githubusercontent.com/OpenZWave/open-zwave/c808b7431fb6c28b408e7fdc5492e46420cb6926/cpp/src/command_classes/BarrierOperator.cpp
#wget -O openzwave/cpp/src/command_classes/BarrierOperator.h https://raw.githubusercontent.com/OpenZWave/open-zwave/c808b7431fb6c28b408e7fdc5492e46420cb6926/cpp/src/command_classes/BarrierOperator.h
#wget -O openzwave/cpp/src/command_classes/CommandClasses.cpp https://raw.githubusercontent.com/OpenZWave/open-zwave/c808b7431fb6c28b408e7fdc5492e46420cb6926/cpp/src/command_classes/CommandClasses.cpp
echo "Building python-openzwave with barrier_operator support\nStage 1..."
make build
make install
rm -Rf openzwave-git/open-zwave-master/
cp -R openzwave/ openzwave-git/
mv openzwave-git/openzwave/ openzwave-git/open-zwave-master/
echo "Building stage 2..."
make install
echo "Deactivating virtualenv"
deactivate
EOF
echo "Creating libmicrohttpd directory"
mkdir libmicrohttpd
chown homeassistant:homeassistant libmicrohttpd
cd /srv/homeassistant/src/libmicrohttpd
echo "Downloading libmicrohttpd-0.9.19"
wget ftp://ftp.gnu.org/gnu/libmicrohttpd/libmicrohttpd-0.9.19.tar.gz
chown homeassistant:homeassistant libmicrohttpd-0.9.19.tar.gz
tar zxvf libmicrohttpd-0.9.19.tar.gz
echo "Building libmicrohttpd-0.9.19"
cd libmicrohttpd-0.9.19
./configure
make
make install
echo "Cloning open-zwave-control-panel"
git clone https://github.com/OpenZWave/open-zwave-control-panel.git
chown -R homeassistant:homeassistant open-zwave-control-panel
cd open-zwave-control-panel
echo "Replacing open-zwave-control-panel source files with barrier_operator support"
#wget -O zwavelib.cpp https://raw.githubusercontent.com/legrego/open-zwave-control-panel/0925251a566a36543e0c6b5cb0b2c1498bddfa68/zwavelib.cpp
echo "Building open-zwave-control-panel"
rm Makefile
wget https://raw.githubusercontent.com/home-assistant/fabric-home-assistant/master/Makefile
chown homeassistant:homeassistant Makefile
make
echo "Linking ozwcp config directory"
ln -sd /srv/homeassistant/lib/python3.*/site-packages/libopenzwave-0.*-linux*.egg/config
echo "Linking Home Assistant OpenZWave config directory"
cd /home/homeassistant/.homeassistant
sudo -u homeassistant ln -sd /srv/homeassistant/lib/python3.*/site-packages/libopenzwave-*-linux*.egg/config
chown -R homeassistant:homeassistant /home/homeassistant/.homeassistant
echo "Patching __init__.py"
# This should create the file for patching
FILE="./__init__.py.diff"
cat <<EOM >$FILE
*** /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py.old 2017-07-09 19:27:23.264954710 -0700
--- /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py 2017-07-03 10:35:09.826370100 -0700
*** 37,43 ****
from .discovery_schemas import DISCOVERY_SCHEMAS
from .util import check_node_schema, check_value_schema, node_name
! REQUIREMENTS = ['pydispatcher==2.0.5', 'python_openzwave==0.4.0.31']
_LOGGER = logging.getLogger(__name__)
--- 37,44 ----
! #REQUIREMENTS = ['pydispatcher==2.0.5', 'python_openzwave==0.4.0.31']
! REQUIREMENTS = ['pydispatcher==2.0.5']
EOM
patch -i __init__.py.diff /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py
echo "Clearing HomeAssistant deps directory"
rm -Rf /home/homeassistant/.homeassistant/deps/*
echo
echo "Installation done!"
echo
echo "If you have issues with this script, please contact @Landrash on gitter.im"
echo "Original script by @dale3h on gitter.im"
echo
You may have to modify the paths depending on your installation. I installed via the AIO installer on my Pi.
Quick way to confirm itâs working is run the OZWCP from the /srv/homeassistant/src/open-zwave-control-panel directory.
