@firstof9 @finity After a another reboot some of the names came back …
The linear did not, before it was something like linear unknow or something like that.
So far the tilt still does not seem to respond in the states.
AppDaemon should not be affected, may be a separate issue.
Now that you have the cover showing up, you should be able to link it in the GUI providing you’ve replaced the zwave component files
https://raw.githubusercontent.com/firstof9/home-assistant/proper-patch/homeassistant/components/cover/init.py
and
https://raw.githubusercontent.com/firstof9/home-assistant/proper-patch/homeassistant/components/cover/zwave.py
They go in your /srv/homeassistant//lib/python3.4/site-packages/homeassistant/components/cover
directory or /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/cover
using AIO.
As for naming the device, you can do that via the zwave config to name your device, or just manually edit the ozwcache_xxxxx.xml file in /home/homeassistant/.homeassistant/
directory or copy your zwcfg_xxxxx.xml on top of it.
If did change some of the permissions on some of the directories. My conf directory is off of .homeassistant.
For me it was ‘_/srv/homeassistant//lib/python3.4/site-packages/homeassistant/components/cove_r’ directory. Now the GUI seems to work and the cover widget for the dashboard.
Default setup for the widget seems pretty bla, I wonder what customizing can be done? Oh well that’s for another thread.
Just to confirm, you are able to monitor and open/close your door now via HA?
Yes. I think going over my lessons learned (otherwise know as mistakes), maybe we can come up with a Hassbain document or better yet, script.
The two python files that was hot patch in the cover directory, will they be in the next release or will I have to update them by hand again?
Along the same lines, will OZW have the patches we applied there?
Yes, please make some kind of documentation. I am have the same issue and I am not very good at using Linux so a detailed guide would be amazing to have for rookies like myself.
Not sure I understand the pros and cons to different methods.
Is there a file that Name = Node#. That way if Node# changes, I change that and all my entities work. Every time I remove/added the garage door opener, it got a new node number. I am going to have two garage door openers.
Edit:
Just tried the zwcfg_xxx.xml. Restarted (hassctl restart) and the node name did not change.
<Node id="12" name="" location="" basic="4" generic="64" specific="7" roletype="5" devicetype="3078" nodetype="0" type="Secure Barrier AddOn" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" secured="true" query_stage="Complete">
<Manufacturer id="14f" name="Linear">
<Product type="4744" id="3530" name="Garage Door One Car" />
</Manufacturer>
Step 1: Stop HA
Step 2: edit the xml (ozwcache_xxxx.xml should be the file it’s reading from) similar to this:
<Node id="12" name="Garage Door" location="" basic="4" generic="64" specific="7" roletype="5" devicetype="3078" nodetype="0" type="Secure Barrier AddOn" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" secured="true" query_stage="Complete">
Step 3: Save the file
Step 4: Start HA
It should now have the name “Garage_Door” in HA.
I am working on a Pull Request to get them into HA.
The OZW files will still work, as long as you modify the __init__.py
file once again.
That was my first mistake, I was doing zwcfg_xxxx.xml.
Also, I see why you have to stop it first.
Off topic somewhat, but does go to understand what we did to get the linear garage door to work. So what did the change do ?
Is that not something ozw developers need to change also?
The change stops HA from auto-downloading the unmodified python_openzwave via pip.
Nope this change was implemented by the HA developers to make things easier for zwave integration.
Well I’ve submitted a PR to get the HA modifications in, that’ll make it easier to get working if/when they merge it in.
Uber excited! Thank you all!
You’ll still have to get the dev version of Python_OpenZwave compiled, but it’ll still be much easier than manually copying files around in homeassistant
I never could get it to work.
I gave up and just bought a zwave dry contact relay and tilt sensor.
both together were cheaper than the linear GDO and WAY easier to get it to work. it was 15 minutes versus 3 or 4 days of trying everything over and over again and it still not working.
it especially made more sense to go with the cheaper/easier alternative since i realized if i ever get another newer style GDO, HA and linear won’t work with the security features of the MyQ systems (which most of the readily accessible ones seem to be) without a connection to the internet and a MyQ gateway (even more $).
hopefully one day this will get fully integrated for those who need it.
thanks @firstof9 for all the help tho. i guess my linux skills need A LOT more work to figure it out!
I did the same I still have the Linear up there ready to reconnect as soon as HASS supports it out of the box …
compiling the dev version of python_openzwave isn’t too complicated
If/when the PR is merged that’s a lot of the battle right there.
@firstof9
Ran into something interesting I can’t quite seem to sort figured you might be able to help. I managed to get openzwave compiled and working but after patching the cover files I get this
2017-07-24 11:35:39 ERROR (Dummy-14) [homeassistant.loader] Error loading homeassistant.components.cover.zwave. Make sure all dependencies are installed
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/loader.py”, line 141, in get_component
module = importlib.import_module(path)
File “/usr/lib/python3.4/importlib/init.py”, line 109, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 2254, in _gcd_import
File “”, line 2237, in _find_and_load
File “”, line 2212, in _find_and_load_unlocked
File “”, line 321, in _call_with_frames_removed
File “”, line 2226, in _find_and_load_unlocked
File “”, line 1200, in _load_unlocked
File “”, line 1129, in _exec
File “”, line 1471, in exec_module
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/cover/init.py”, line 16, in
from homeassistant.loader import bind_hass
ImportError: cannot import name ‘bind_hass’
Any thoughts? Let me know if you need any further information.
Yup, use these links for the patch:
https://raw.githubusercontent.com/firstof9/home-assistant/c680679a636c0a517fbbf9536643941e1088c393/homeassistant/components/cover/__init__.py
https://raw.githubusercontent.com/firstof9/home-assistant/c680679a636c0a517fbbf9536643941e1088c393/homeassistant/components/cover/zwave.py
The latest version on GitHub have upcoming merged changes mixed in
Enjoy!
EDIT: Updated link @Segfaul198
