Here is what OZWCP shows for the device:
20 LBR+ Z-Wave+ node Always On Slave Access Control Sensor Linear Unknown: type=4744, id=3530 Garage Door Opener Garage off 7:37:58 PM Dynamic
Under the Current Values menu is where I have an Open switch that lets me send the open/close command.
In the States view in the GUI it has this:
sensor.garage_door_opener_access_control_20 254 friendly_name: Garage Door Opener Access Control
node_id: 20
sensor.garage_door_opener_alarm_level_20 0 friendly_name: Garage Door Opener Alarm Level
node_id: 20
sensor.garage_door_opener_alarm_type_20 0 friendly_name: Garage Door Opener Alarm Type
node_id: 20
sensor.garage_door_opener_burglar_20 254 friendly_name: Garage Door Opener Burglar
node_id: 20
sensor.garage_door_opener_sourcenodeid_20 0 friendly_name: Garage Door Opener SourceNodeId
node_id: 20
And here is what Home Assistantās log shows:
16-10-02 00:39:36 homeassistant.components.zwave: Adding Node_id=20 Generic_command_class=64, Specific_command_class=7, Command_class=113, Value type=Byte, Genre=User
16-10-02 00:39:36 homeassistant.components.zwave: Component=light Node_id=20 query start
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event platform_discovered[L]: discovered=value_id=72057594379517953, node_id=20, service=load_platform.sensor, platform=zwave>
16-10-02 00:39:36 homeassistant.components.zwave: Component=switch Node_id=20 query start
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state sensor.garage_door_opener_alarm_type_20=0; friendly_name=Garage Door Opener Alarm Type, location=Garage, node_id=20 @ 2016-10-01T19:39:36.571023-05:00>, old_state=None, entity_id=sensor.garage_door_opener_alarm_type_20>
16-10-02 00:39:36 homeassistant.components.zwave: Component=binary_sensor Node_id=20 query start
16-10-02 00:39:36 homeassistant.components.zwave: Component=lock Node_id=20 query start
16-10-02 00:39:36 homeassistant.components.zwave: Component=cover Node_id=20 query start
16-10-02 00:39:36 homeassistant.components.zwave: Component=climate Node_id=20 query start
16-10-02 00:39:36 homeassistant.components.zwave: Component=sensor Node_id=20 query start
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event platform_discovered[L]: discovered=value_id=72057594379517969, node_id=20, service=load_platform.sensor, platform=zwave>
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state sensor.garage_door_opener_alarm_level_20=0; friendly_name=Garage Door Opener Alarm Level, location=Garage, node_id=20 @ 2016-10-01T19:39:36.596024-05:00>, old_state=None, entity_id=sensor.garage_door_opener_alarm_level_20>
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event platform_discovered[L]: discovered=value_id=72057594379517985, node_id=20, service=load_platform.sensor, platform=zwave>
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state sensor.garage_door_opener_sourcenodeid_20=0; friendly_name=Garage Door Opener SourceNodeId, location=Garage, node_id=20 @ 2016-10-01T19:39:36.614236-05:00>, old_state=None, entity_id=sensor.garage_door_opener_sourcenodeid_20>
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event platform_discovered[L]: discovered=value_id=72057594379518097, node_id=20, service=load_platform.sensor, platform=zwave>
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state sensor.garage_door_opener_access_control_20=254; friendly_name=Garage Door Opener Access Control, location=Garage, node_id=20 @ 2016-10-01T19:39:36.633739-05:00>, old_state=None, entity_id=sensor.garage_door_opener_access_control_20>
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event platform_discovered[L]: discovered=value_id=72057594379518113, node_id=20, service=load_platform.sensor, platform=zwave>
16-10-02 00:39:36 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state sensor.garage_door_opener_burglar_20=254; friendly_name=Garage Door Opener Burglar, location=Garage, node_id=20 @ 2016-10-01T19:39:36.654044-05:00>, old_state=None, entity_id=sensor.garage_door_opener_burglar_20>
