Link M5 Atom Echo to external speaker
Small followup: I’ve managed to modify the newest yaml (25.6.1) incorporating your changes and everything is working like a charm since 2 days :slight_smile: Here is the modified yaml:
substitutions:
  friendly_name: Atom Echo sypialnia
esphome:
  name_add_mac_suffix: false
  friendly_name: ${friendly_name}
  min_version: 2025.5.0
esp32:
  board: m5stack-atom
  cpu_frequency: 240MHz
  framework:
    type: esp-idf
logger:
api:
  encryption:
    key: "your key"
ota:
  - platform: esphome
    password: "your password"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Atom-Echo-Sypialnia"
captive_portal:
button:
  - platform: factory_reset
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO33
    i2s_bclk_pin: GPIO19
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO23
    adc_type: external
    pdm: true
    sample_rate: 16000
    correct_dc_offset: true
speaker:
    i2s_dout_pin: GPIO22
    dac_type: external
    bits_per_sample: 16bit
    sample_rate: 16000
    channel: stereo  # The Echo has poor playback audio quality when using mon audio
    buffer_duration: 60ms
media_player:
  - platform: speaker
    announcement_pipeline:
      speaker: echo_speaker
      format: WAV
    codec_support_enabled: false
    buffer_size: 6000
    files:
      - id: timer_finished_wave_file
        file: https://github.com/esphome/wake-word-voice-assistants/raw/main/sounds/timer_finished.wav
    on_announcement:
      - if:
            - microphone.is_capturing:
          then:
            - script.execute: stop_wake_word
      - light.turn_on:
          blue: 100%
          red: 0%
          green: 0%
          brightness: 100%
          effect: none
    on_idle:
      - script.execute: start_wake_word
      - script.execute: reset_led
voice_assistant:
  micro_wake_word:
  microphone:
    microphone: echo_microphone
    channels: 0
    gain_factor: 4
  media_player: echo_media_player
  noise_suppression_level: 2
  auto_gain: 31dBFS
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - if:
          switch.is_on: call_script_message
        then:
          - logger.log: "calling script with message (instead of playing directly to media player)"
          - homeassistant.service:
              service: !lambda 'return id(script_id).state.c_str();'
                message: !lambda 'return x;'
        else:
          - if:
                switch.is_on: use_remote_media_player
              then:
                - logger.log: "using remote media player"
                - speaker.volume_set: 10%
                    service: tts.cloud_say
                      entity_id: !lambda 'return id(media_player_entity_id).state.c_str();'
              else:
                - logger.log: "using internal speaker"
                - speaker.volume_set: 100%
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_end:
    # Handle the "nevermind" case where there is no announcement
    - wait_until:
          - media_player.is_announcing:
        timeout: 0.5s
    # Restart only mWW if enabled; streaming wake words automatically restart
    - if:
          - lambda: return id(wake_word_engine_location).state == "On device";
        then:
          - wait_until:
              - and:
                  - not:
                      voice_assistant.is_running:
                  - not:
                      speaker.is_playing:
          - lambda: id(va).set_use_wake_word(false);
          - micro_wake_word.start:
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 2s
  on_client_connected:
    - delay: 2s  # Give the api server time to settle
  on_client_disconnected:
  on_timer_finished:
    - wait_until:
        not:
    - switch.turn_on: timer_ringing
    - light.turn_on:
        red: 0%
        green: 100%
        blue: 0%
        brightness: 100%
    - if:
          switch.is_on: call_alarm_script
        then:
          - logger.log: "calling alarm script"
              service: !lambda 'return id(alarm_script_id).state.c_str();'
    - wait_until:
        - switch.is_off: timer_ringing
    - light.turn_off: led
    - switch.turn_off: timer_ringing
binary_sensor:
  # button does the following:
  # short click - stop a timer
  # if no timer then restart either microwakeword or voice assistant continuous
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    disabled_by_default: true
    entity_category: diagnostic
    on_multi_click:
      - timing:
          - ON for at least 50ms
          - OFF for at least 50ms
        then:
          - logger.log: "single button short click"
          - if:
                switch.is_on: timer_ringing
              then:
              else:
      - timing:
          - ON for at least 10s
        then:
          - logger.log: "single button long click"
          - button.press: factory_reset_btn
light:
  - platform: esp32_rmt_led_strip
    entity_category: config
    pin: GPIO27
    default_transition_length: 0s
    chipset: SK6812
    num_leds: 1
    rgb_order: grb
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
script:
  - id: reset_led
    then:
      - if:
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 100%
                green: 89%
                blue: 71%
                brightness: 60%
                effect: none
          else:
            - if:
                  - lambda: return id(wake_word_engine_location).state != "On device";
                then:
                  - light.turn_on:
                      red: 0%
                      green: 100%
                      blue: 100%
                      brightness: 60%
                      effect: none
                else:
  - id: start_wake_word
    then:
      - if:
            and:
              - not:
                  - voice_assistant.is_running:
          then:
      - if:
            and:
              - not:
              - lambda: return id(wake_word_engine_location).state == "In Home Assistant";
          then:
            - lambda: id(va).set_use_wake_word(true);
            - voice_assistant.start_continuous:
  - id: stop_wake_word
    then:
      - if:
          then:
            - voice_assistant.stop:
      - if:
          then:
            - micro_wake_word.stop:
switch:
    name: Use listen light
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
    on_turn_off:
    name: Use remote media player
    optimistic: true
    on_turn_on:
      - logger.log: "use remote media player turned on"
      - logger.log:
          format: "current media player entity: %s"
          args: ["id(media_player_entity_id).state.c_str()"]
    on_turn_off:
      - logger.log: "use remote media player turned off"
      - logger.log:
    name: Call script with message
    optimistic: true
    on_turn_on:
      - logger.log: "call script with message turned on"
    on_turn_off:
      - logger.log: "call script with message turned off"
    name: Call alarm script
    optimistic: true
    on_turn_on:
      - logger.log: "call alarm script turned on"
    on_turn_off:
      - logger.log: "call alarm script turned off"
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
      # Turn off the repeat mode and disable the pause between playlist items
      - lambda: |-
              id(echo_media_player)
                ->make_call()
                .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_OFF)
                .set_announcement(true)
                .perform();
              id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 0);
      # Stop playing the alarm
      - media_player.stop:
          announcement: true
    on_turn_on:
      # Turn on the repeat mode and pause for 1000 ms between playlist items/repeats
      - lambda: |-
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_REPEAT_ONE)
              .perform();
            id(echo_media_player)->set_playlist_delay_ms(speaker::AudioPipelineType::ANNOUNCEMENT, 1000);
      - media_player.speaker.play_on_device_media_file:
          media_file: timer_finished_wave_file
          announcement: true
      - delay: 15min
text:
    name: Media Player Entity ID
    mode: text
    optimistic: true
    restore_value: true
    on_value:
      then:
        - logger.log:
            format: "Set new media player entity: %s"
            args: ["x.c_str()"]
    mode: text
    optimistic: true
    restore_value: true
    on_value:
      then:
        - logger.log:
            format: "Set new script: %s"
            args: ["x.c_str()"]
    name: Script on Alarm ID
    mode: text
    optimistic: true
    restore_value: true
    on_value:
      then:
        - logger.log:
            format: "Set new alarm script: %s"
            args: ["x.c_str()"]
select:
    name: Wake word engine location
    optimistic: true
    restore_value: true
    options:
      - In Home Assistant
      - On device
    initial_option: On device
    on_value:
      - if:
            lambda: return x == "In Home Assistant";
          then:
            - delay: 500ms
      - if:
            lambda: return x == "On device";
          then:
            - delay: 500ms
micro_wake_word:
  on_wake_word_detected:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
  vad:
  models:
    - model: okay_nabu
    - model: hey_mycroft
    - model: hey_jarvis
Now, thanks to you, I’m totally happy with my two echos. One of them is constantly switched to an external speaker via VLC and another is linked to my Windows computer speakers via HASS.Agent and switched back to internal echo speaker by an automation when the HASS.Agent player becomes unavalilable (after Windows shutting down). Both are working with continued conversation with zero problems :slight_smile: Thank you for your yaml :slight_smile:
