Hi, looking forward to it, that gives us finally a way to actually play something in core!
Btw, van you help me with below, with the hacs one, I used the play media services to play radio stations to it, bur can’t figure out how todo it with the core?
@domain_int I think you need Home Assistant core 2024.9.0 for WiiM Pro devices.
On my system Home Assistant discovers the WiiM Pro devices (hubs), not sure what to do next.
Now that this is fixed with the latest update, is it possible to customize the input audio sources? I cannot select “Wi-fi” for example, and previously I was able to have internet streams as custom audio sources.
Hi, I’m just setting up a Linkplay integration for my Arylic Up2Stream devices, and have gone with with HACS custom integration for the same reasons as others, i.e. I want to use presets and link multiple devices.
I’ve hit a problem with the play/pause and play/stop buttons when setting up a mini-media-player card, that the linkplay media player doesn’t accept re-starting a radio stream with media_play, or media_play_pause service. Is there a way round this to make the play/pause or play/stop button work as expected?
Also, does the icecast_metadata: ‘StationNameSongTitle’ work with many internet radio stations? I’m just getting the station name.
If you require configuration support then open a new topic in the Configuration category.
If you would like new features added to the existing integration please open a new feature request for each new feature (do not put more than one feature in the request).
