ListenBrainz Scrobbler
Custom Home Assistant integration that submits listens from selected media_player entities to a ListenBrainz-compatible endpoint. It was built for multi-scrobbler, which emulates the ListenBrainz API so it can forward scrobbles to Last.fm, ListenBrainz, Maloja and the rest of its clients.
Installation
Marketplace (recommended)
  1. Open Settings → Marketplace.
  2. Search for ListenBrainz Scrobbler and select Download.
  3. Restart Home Assistant — integration code is only loaded at startup.
If it is not in the list yet, add this repository as a custom repository first: HACS → ⋮ → Custom repositories, paste https://github.com/Thrasher2020/home-assistant-listenbrainz-scrobbler, choose Integration, then download it.
Manual
  1. Copy custom_components/listenbrainz_scrobbler/ into your Home Assistant custom_components/ folder.
  2. Restart Home Assistant.
Setup
  1. Go to Settings → Devices & Services → Add Integration and search for ListenBrainz Scrobbler.
  2. Enter a name, the server URL and the token configured on the multi-scrobbler ListenBrainz endpoint.
  3. On the next page tick the media players to watch and adjust the scrobble settings.
Server URL
multi-scrobbler has two ListenBrainz entry points. Either form is accepted:
Mode What to enter What is posted to
Standard (recommended) http://192.168.1.23:9078 http://192.168.1.23:9078/1/submit-listens
Slug http://192.168.1.23:9078/api/listenbrainz/<slug> .../<slug>/submit-listens
Full path http://192.168.1.23:9078/1/submit-listens used unchanged
The token is sent as Authorization: Token <token>; it must match the LZE_TOKEN (or token) configured on the multi-scrobbler source.
Behaviour
  • Tracks with a known duration are scrobbled at the configured percentage (default 50%), or after 4 minutes, whichever comes first.
  • Radio / streams (media_duration 0 or unknown, or a ...://radio/... content id) have no reliable duration, so they are scrobbled after the configured radio time (default 30 seconds) of continuous playback.
  • Now playing is sent once per track when enabled.
  • Year cleanup applies only to radio: a trailing (89) or (1989) is removed, so Lonely (89) is submitted as Lonely.
  • Music Assistant radio puts the station name in media_album_name, so the album is dropped for radio listens instead of scrobbling the station as the album.
  • Music Assistant slash-joined artists (Artist A/Artist B) are reduced to the first artist; AC/DC is left alone.
A play is marked as submitted before the HTTP request, so a timeout cannot produce duplicate scrobbles on the next check. The trade-off is that a failed request loses that one play; the warning is in the log.
Notes
  • Each entry has a unique id derived from URL + token, so the same multi-scrobbler server can be used with more than one token.
  • Options (players, URL, token, thresholds, year cleanup) can be edited from the integration’s Configure button; the entry reloads automatically.
  • Watching is event-driven, with a 10-second progress check while players are playing.
  • Select one entity per physical player. If you select both the Music Assistant player and the Sonos/native player for the same speaker, every play is submitted twice.
This is no longer a thing. I suggest you update your instructions for Marketplace.
This might help: My Link / EZ-Button to help users install your App / Marketplace Item
Noted. These were all written before Marketplace, so I’ll work my way through my integrations and update the readme.
