I’m a little confused and haven’t really found anything that explains this to me:
I have a few input_datetime
inputs, most of them as just times triggering automations daily. I’ve now defined an input_datetime
with both date and time - the intention is to trigger an automation at a specific time on a specific date.
For the daily automations, I trigger them like this:
platform: template
value_template: "{{ states('sensor.time') == (state_attr('input_datetime.tid_for_slukk_lys_helgedager', 'timestamp') | int | timestamp_custom('%H:%M', False)) }}"
This works fine. If input_datetime.tid_for_slukk_lys_helgedager
is set to 00:05
, the automation triggers at 00:05
. Checking the value of the input_datetime
in the template checker with:
{{ (state_attr('input_datetime.tid_for_slukk_lys_helgedager', 'timestamp') | int | timestamp_custom('%H:%M',False)) }}
I get 00:05
. All well so far.
If I change the local_boolean
parameter (the second parameter in timestamp_custom
) to True
, I get 01:05
, which is not what I want, so I stick with local_boolean
set to False
However, for both time and date, I’ve set input_datetime.tid_for_sla_pa_varme_i_hytta
to 2019-11-08 07:00
. If I check its value in the template checker with
{{ (state_attr('input_datetime.tid_for_sla_pa_varme_i_hytta', 'timestamp') | int | timestamp_custom('%H:%M, %Y-%m-%d', False)) }}
I get 06:00, 2019-11-08
. If I change the local_boolean
to True
, I get 07:00, 2019-11-08
I’m not getting why I have to use local_boolean
set to False
for just time, but True
for time and date.
Any ideas or pointers?
