(it’s moving West to East)
and I’m going to have to head to bed. So I won’t be taking any more webcam screencaps lol.
I think the new formula seems to show it’s pretty good - though interestingly right now, the old formula is showing a higher percentage than the new one (because I’m above zero, and have high humidity) - so maybe we can do some sort of hybrid formula?
For Snow Probability, bottom graph, orange is your old algorithm, blue is the new one. I thought this graph summarized how well they actually track together, at least at higher probabilities. It never snowed at my house for this, but it did snow 20 miles away where I was at the time.
I included the Lightning Probability for show, I’m working on refining it (Orange). Blue on this graph is Fog Probability which is coming from the integration.
Apparent temperature is also a work in progress, it compares air temperature, wind chill (feels like), and a heat index temperature (slightly different from WBGT Wet Bulb Globe Temperature).
I modified that code (Zambretti) in python. I don’t take into account pressure changes as originally designed but it works fairly well.
If you could share some of those formulas in the book, I would be willing to try some out. I did incorporate a snow prediction formula based off a extensive study of personal weather stations that someone brought to my attention.
Well, by component, I was assuming that it was something integrated into home assistant. Is that the case? If so, I’d certainly like to see what you’ve got. I thought that there might be some guide on how to do it that you followed, and if so, where is it? I’m especially interested in using them in Node Red.
I pull mine from UDP via WeatherFlow2MQTT into Home Assistant; the WF2MQTT container does all the work (it is available as an add-on also). But if you want to do it in Node-Red give me a little bit of time and I can pull/update what I have been using for testing.
Ideally a generic custom_component would take in all of the sensors and just create a standard weather entity able to be used with any normal weather card, but doesn’t seem to be the case yet.
