I have been using Local Tuya for a couple months and its worked great until now. I for some reason on the 7/13 I lost all Local Tuya on the HA. Nothing has changed with the setting or config. The same Tuya devices are still functioning normally with the cloud based Tuya integration.
wow ok at least I know its not something I did. I believe there are a few different local tuya integrations… Maybe I’ll try the other one and see if that works. I’m glad I didn’t waste my time trying to reinstall each device.
After deleting completely Local Tuya Integration from HACS, restarting everything, configuring it again and adding the device again (needed some tries as it normally fails when adding the device) finally it´s working again.
I haven´t done anything different this time so I can´t tell what was the problem.
