Location service does not work for me
Hi
Love the new app although the location update between app and HA does not seem to work for me…
I Have 2 iPhone 6’s with 1.02 app and 0.42.4 HA version running at home.
Location enabled on both within the app and set to “always” in the privacy -> location setting for the iPhones.
No location update on the HA state page for any of them.
When I try to manually send location from the app, on 1 of the phones I see several error messages in the log correlating with the attempt (for the other phone with same action - no message appears in the log).
Check out the log errors here: https://pastebin.com/G9HjK7gZ
Both iPhones are long since listed in the known_devices (hide_if_away: false, track: true)
Up until yesterday I was using the iCloud service which I hope to replace with the app - but it does not seem to work (icloud reference removed from the config).
What should I do about it? anyone else has similar issues?
Have yoy added track_ios in the config?
zone.home:
    track_ios: true
I missed that, I set up mine in the 1.0 app, sorry for that.
So @cameron way is it not working for @Amir974 ?
It looks like you have the wrong name in your apps Device ID.
voluptuous.error.Invalid: invalid slug refael’s iphone (try refaels_iphone)
Thanks @cameron… so messing up with the ids in the known_devices is no good :weary:
got it!
I got the same problem.
"Location failed to update
Failed to send current location to server. The error was The operation couldn’t be completed. (SwiftLocation.Location-Error error 3.)
Ok now it worked. So it is an intermittent problem. But I have to manually invoke the location update from the HA
app. Even though I have it set to update always. It is version 1.1.1
I use This system and work fine for me
In spanish , sorry
Fernando,
Thanks very much for the information! I will give a try and let you know.
Best,
Garry
Is there a way to automatically have HA send a one shot to the map every 10mins or so?
This would sole a lot of location problems!
