Great! I’m pretty happy with the dutch translation after all. No need for other languages from my side. ![]()
Terrific card, Bedankt!
How can I switch between multiple people or show multiple people-paths? Or do I need to create a dashboard for each person? Thanks
The latest released version of the card supports multiple people. Have a look at the repo for documentation
Fantastic card and very easy to implement. First, thank you for your great work. Second, I’d like to ask if any changes could be made through a card mod or some other modification. Here’s a list of suggestions: 1. In the date picker, could the date type be modified? For example, March 3, 2026 would be perfect; there would be no need to specify the day (Tuesday). 2. Is it possible to change its size? As you can see in the image, it doesn’t cover the entire space, and the three dots are visible. 3. Is it possible to change the color and size of the icons in the timeline? 4. Similarly, is it possible to change the blue color of the timeline bar? 5. The text size in the locations is very good, but perhaps it could be made smaller. 6. Translation: I have no problem with it being “moving” as it’s perfectly understandable, but if it could be changed to other languages (including Spanish) that would be fantastic. Thank you very much in advance. I look forward to your reply.
I love this! Is there any way to change the map view to a hybrid or satellite view?
Thanks all for you comments and remarks!
On a general note: for the next few weeks, I won’t be able to work much on this, but I love to receive your suggestions. In case you have feature requests, please submit them on the Issues tab of the Github repo so I can keep track of all the requests. You’re always welcome to submit pull requests with additional features
Specifically:
@SPESINO could you submit point 1 as a feature request in Github?
Points 2 to 5 I am not planning on implementing, I would suggest using the card-mod module and change the CSS.
Point 6, you are more than welcome to submit a PR on Github with the Spanish translations.
@gschiff I like the suggestion, could you submit it on Github?
thanks for the work, i really like it!
One thing that struck me, every now and then my HA map card locates at Amsterdam and when it does it isn’t showing the persons anymore at all. The person tracked in your timeline card does still appear as well as on the correct location (not Amsterdam), it just disappears on my “normal” HA map. This happens randomly it seems, at first I noticed it and there was an update available and that solved it. Also its happening more often on my phone compared to the laptop.
Thanks @marcadriaanse, could you raise this as an issue in the Github repository, that way I can keep track. It will have something to do with the rendering of the card that is not executed at the right moment, as Amsterdam is the default location (taken from the native HA map card).
done! Thanks for your dedication, keepup the good work!
