Hi community,
I need urgent help regarding this error which happens when trying to reload template entities (from the dev tools section):
Logger: homeassistant.components.websocket_api.http.connection
Source: setup.py:490
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 01:52:32 (3 occurrences)
Last logged: 02:19:25
[546186835808] unsupported operand type(s) for +=: 'float' and 'datetime.timedelta'
[547470548208] unsupported operand type(s) for +=: 'float' and 'datetime.timedelta'
[546987027824] unsupported operand type(s) for +=: 'float' and 'datetime.timedelta'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 199, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1820, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1857, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 874, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/template/__init__.py", line 51, in _reload_config
await async_reload_integration_platforms(hass, DOMAIN, PLATFORMS)
File "/usr/src/homeassistant/homeassistant/helpers/reload.py", line 53, in async_reload_integration_platforms
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/reload.py", line 98, in _resetup_platform
await _async_reconfig_platform(platform, root_config[integration_platform])
File "/usr/src/homeassistant/homeassistant/helpers/reload.py", line 138, in _async_reconfig_platform
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 238, in async_setup
await self._async_setup_platform(async_create_setup_task)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 299, in _async_setup_platform
with async_start_setup(hass, [full_name]):
File "/usr/local/lib/python3.10/contextlib.py", line 142, in __exit__
next(self.gen)
File "/usr/src/homeassistant/homeassistant/setup.py", line 490, in async_start_setup
setup_time[integration] += time_taken
TypeError: unsupported operand type(s) for +=: 'float' and 'datetime.timedelta'
I absolutely don’t get where that points at or originates from.
Template entities render fine when starting HA. ![]()
But once reloading them manually above error is shown…
…and ALL template entities are not rendering - meaning unavailable!
- I compared recent changes to all template entities (all my *.yaml files) and could only find these added lines to three template sensors:
a.
availability: "{{ states('sensor.network_throughput_in_end0') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] }}"
b.
availability: "{{ states('sensor.network_throughput_out_end0') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] }}"
c.
availability_template: >-
states('sensor.plug_a') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_b') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_c') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_d') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_e') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_f') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_g') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_h') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_i') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_j') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_k') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', ''] and
states('sensor.plug_l') not in ['NULL', 'null', 'none', 'undefined', 'unavailable', 'unknown', '']
I don’t think that’s relevant, isn’t it.
2nd change due to a HA restart after 15 days: custom integrations have been updated. Also not relevant as this error is about template entities, right?
3rd change was adding a device to an integration. Also not related to template entities at all I think.
