I’m struggling a bit with configuring the ZIF5030 from LogicGroup (https://logic-group.com/product/zif5030/?lang=en#tab-dl_tab), which offers 10 different digital outputs (switches). NB! It’s also sold under the name HeatIt Zwater.
Issue:
When adding the ZIF5030 (as secure), I only see 1 switch - the root endpoint.
Steps taken already:
- I’ve tried to modify the zwcfgX.xml file to reflect the heatit20a as pr HeatIt z-water , but doesn’t change anything.
- I did try to switch over to the zwave beta integration (openzwave 1.6), but it didn’t add any additional switches.
Current environment:
- HASS Core 0.117
- Zwave.me zwave controller
- Standard zwave integration (not the beta)
- zwcfgx.xml (see below)
If I left something out, please let me know and I’d be happy to share. Any suggestions to get those switches into HASS would be highly appreciated !
Thanks in advance.
Best regards,
Tommy
<?xml version="1.0" encoding="utf-8" ?>
<Driver xmlns="http://code.google.com/p/open-zwave/" version="3" home_id="0xc6e5ae92" node_id="1" api_capabilities="0" controller_capabilities="40" poll_interval="30000" po
ll_interval_between="false">
<Node id="1" name="" location="" basic="2" generic="2" specific="1" type="Static PC Controller" listening="true" frequentListening="false" beaming="true" routing="t
rue" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="115" name="Z-Wave.Me">
<Product type="400" id="1" name="ZME_UZB1 USB Stick" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" after_mark="true">
<Instance index="1" />
<Value type="byte" genre="basic" instance="1" index="0" label="Basic" units="" read_only="false" write_only="false" verify_changes="false" p
oll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
</CommandClasses>
</Node>
<Node id="2" name="" location="" basic="4" generic="16" specific="6" roletype="5" devicetype="5376" nodetype="0" type="Valve Open Close" listening="true" frequentLi
stening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" secured="true" query_stage="Complete">
<Manufacturer id="234" name="Logic Soft">
<Product type="3" id="10e" name="Unknown: type=0003, id=010e" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="5" mapping="37">
</CommandClass>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" issecured="true" innif="true">
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" p
oll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="user" instance="2" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" p
<Value type="bool" genre="user" instance="3" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" p
<Value type="bool" genre="user" instance="4" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" p
</CommandClass>
<CommandClass id="38" name="COMMAND_CLASS_SWITCH_MULTILEVEL" version="0" request_flags="1" after_mark="true" issecured="true" innif="true">
<Value type="byte" genre="user" instance="1" index="0" label="Level" units="" read_only="false" write_only="false" verify_changes="false" po
<Value type="button" genre="user" instance="1" index="1" label="Bright" units="" read_only="false" write_only="true" verify_changes="false"
poll_intensity="0" min="0" max="0" />
<Value type="button" genre="user" instance="1" index="2" label="Dim" units="" read_only="false" write_only="true" verify_changes="false" pol
<Value type="bool" genre="system" instance="1" index="3" label="Ignore Start Level" units="" read_only="false" write_only="false" verify_cha
nges="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="byte" genre="system" instance="1" index="4" label="Start Level" units="" read_only="false" write_only="false" verify_changes="f
alse" poll_intensity="0" min="0" max="255" value="0" />
</CommandClass>
<CommandClass id="90" name="COMMAND_CLASS_DEVICE_RESET_LOCALLY" version="1" request_flags="5" issecured="true" innif="true">
</CommandClass>
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="5" issecured="true" innif="true" scenecount="0">
<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="fal
se" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
<CommandClass id="94" name="COMMAND_CLASS_ZWAVEPLUS_INFO" version="1" request_flags="5" innif="true">
<Instance index="2" endpoint="1" />
<Instance index="3" endpoint="2" />
<Instance index="4" endpoint="3" />
<Instance index="5" endpoint="4" />
<Instance index="6" endpoint="5" />
<Instance index="7" endpoint="6" />
<Instance index="8" endpoint="7" />
<Instance index="9" endpoint="8" />
<Instance index="10" endpoint="9" />
<Instance index="11" endpoint="10" />
<Instance index="12" endpoint="11" />
<Instance index="13" endpoint="12" />
<Instance index="14" endpoint="13" />
<Instance index="15" endpoint="14" />
<Value type="byte" genre="system" instance="1" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
"false" poll_intensity="0" min="0" max="255" value="1" />
<Value type="short" genre="system" instance="1" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
"false" poll_intensity="0" min="-32768" max="32767" value="5376" />
<Value type="short" genre="system" instance="1" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="2" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
"false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="2" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
"false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="2" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="3" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="3" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="3" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="4" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="4" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="4" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="5" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="5" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="5" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="6" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="6" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="6" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="7" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="7" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="7" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="8" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="8" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="8" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="9" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="9" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes=
<Value type="short" genre="system" instance="9" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fals
<Value type="byte" genre="system" instance="10" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes
="false" poll_intensity="0" min="0" max="255" value="0" />
<Value type="short" genre="system" instance="10" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes
="false" poll_intensity="0" min="-32768" max="32767" value="0" />
<Value type="short" genre="system" instance="10" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fal
<Value type="byte" genre="system" instance="11" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="11" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="11" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fal
<Value type="byte" genre="system" instance="12" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="12" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="12" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fal
<Value type="byte" genre="system" instance="13" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="13" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="13" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fal
<Value type="byte" genre="system" instance="14" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="14" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="14" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fal
<Value type="byte" genre="system" instance="15" index="0" label="ZWave+ Version" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="15" index="1" label="InstallerIcon" units="" read_only="true" write_only="false" verify_changes
<Value type="short" genre="system" instance="15" index="2" label="UserIcon" units="" read_only="true" write_only="false" verify_changes="fal
</CommandClass>
<CommandClass id="96" name="COMMAND_CLASS_MULTI_INSTANCE/CHANNEL" version="4" request_flags="1" issecured="true" innif="true">
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5" issecured="true" innif="true">
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="5" issecured="true" innif="true">
</CommandClass>
<CommandClass id="115" name="COMMAND_CLASS_POWERLEVEL" version="1" request_flags="5" issecured="true" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Powerlevel" units="dB" read_only="false" write_only="false" verify_changes="
false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Normal" value="0" />
<Item label="-1dB" value="1" />
<Item label="-2dB" value="2" />
<Item label="-3dB" value="3" />
<Item label="-4dB" value="4" />
<Item label="-5dB" value="5" />
<Item label="-6dB" value="6" />
<Item label="-7dB" value="7" />
<Item label="-8dB" value="8" />
<Item label="-9dB" value="9" />
</Value>
<Value type="byte" genre="system" instance="1" index="1" label="Timeout" units="seconds" read_only="false" write_only="false" verify_changes
<Value type="button" genre="system" instance="1" index="2" label="Set Powerlevel" units="" read_only="false" write_only="true" verify_change
s="false" poll_intensity="0" min="0" max="0" />
<Value type="byte" genre="system" instance="1" index="3" label="Test Node" units="" read_only="false" write_only="false" verify_changes="fal
<Value type="list" genre="system" instance="1" index="4" label="Test Powerlevel" units="dB" read_only="false" write_only="false" verify_chan
ges="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="short" genre="system" instance="1" index="5" label="Frame Count" units="" read_only="false" write_only="false" verify_changes="
<Value type="button" genre="system" instance="1" index="6" label="Test" units="" read_only="false" write_only="true" verify_changes="false"
<Value type="button" genre="system" instance="1" index="7" label="Report" units="" read_only="false" write_only="true" verify_changes="false
<Value type="list" genre="system" instance="1" index="8" label="Test Status" units="" read_only="true" write_only="false" verify_changes="fa
<Item label="Failed" value="0" />
<Item label="Success" value="1" />
<Item label="In Progress" value="2" />
</Value>
<Value type="short" genre="system" instance="1" index="9" label="Acked Frames" units="" read_only="true" write_only="false" verify_changes="
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="5" issecured="true" innif="true">
<Associations num_groups="13">
<Group index="1" max_associations="5" label="Group 1" auto="true" multiInstance="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="5" label="Group 2" auto="false" multiInstance="true" />
<Group index="3" max_associations="5" label="Group 3" auto="false" multiInstance="true" />
<Group index="4" max_associations="5" label="Group 4" auto="false" multiInstance="true" />
<Group index="5" max_associations="5" label="Group 5" auto="false" multiInstance="true" />
<Group index="6" max_associations="5" label="Group 6" auto="false" multiInstance="true" />
<Group index="7" max_associations="5" label="Group 7" auto="false" multiInstance="true" />
<Group index="8" max_associations="5" label="Group 8" auto="false" multiInstance="true" />
<Group index="9" max_associations="5" label="Group 9" auto="false" multiInstance="true" />
<Group index="10" max_associations="5" label="Group 10" auto="false" multiInstance="true" />
<Group index="11" max_associations="5" label="Group 11" auto="false" multiInstance="true" />
<Group index="12" max_associations="5" label="Group 12" auto="false" multiInstance="true" />
<Group index="13" max_associations="5" label="Group 13" auto="false" multiInstance="true" />
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="5" issecured="true" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_chang
es="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_chan
ges="false" poll_intensity="0" min="0" max="0" value="4.61" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_c
hanges="false" poll_intensity="0" min="0" max="0" value="0.52" />
</CommandClass>
<CommandClass id="142" name="COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION" version="1" request_flags="5" issecured="true" innif="true">
<Node id="1" />
</Group>
</Associations>
</CommandClass>
<CommandClass id="152" name="COMMAND_CLASS_SECURITY" version="1" request_flags="5" innif="true">
<Instance index="1" endpoint="1" />
<Instance index="2" endpoint="2" />
<Instance index="3" endpoint="3" />
<Instance index="4" endpoint="4" />
<Instance index="5" endpoint="5" />
<Instance index="6" endpoint="6" />
<Instance index="7" endpoint="7" />
<Instance index="8" endpoint="8" />
<Instance index="9" endpoint="9" />
<Instance index="10" endpoint="10" />
<Instance index="11" endpoint="11" />
<Instance index="12" endpoint="12" />
<Instance index="13" endpoint="13" />
<Instance index="14" endpoint="14" />
<Value type="bool" genre="system" instance="1" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="2" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="3" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="4" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="5" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="6" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="7" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="8" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="9" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false"
<Value type="bool" genre="system" instance="10" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false
" poll_intensity="0" min="0" max="0" value="False" />
<Value type="bool" genre="system" instance="11" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false
<Value type="bool" genre="system" instance="12" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false
<Value type="bool" genre="system" instance="13" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false
<Value type="bool" genre="system" instance="14" index="0" label="Secured" units="" read_only="true" write_only="false" verify_changes="false
</CommandClass>
</CommandClasses>
</Node>
</Driver>
