Login Nabu Casa fails
I am using gitlab-ci and have a runner on my host system. HA runs in docker. The last line of the deployment script is a docker-compose restart hass. Works like a charm.
Only problem is that after the docker restart i can no longer connect from outside to my system. Access locally (ip:8123) works, but the external nabu casa link (https://xxxx.ui.nabu.casa/lovelace/default_view) is not working. It shows the retry dialogue. Login into nabu casa and reconnect fails as well.
Any idea what I should look for?
Regards
Ralf
When I check the cloud integration it says “remote access is being prepared, please be patient” (German is “Der Fernzugriff wird vorbereitet. Wir werden Sie benachrichtigen, wenn alles fertig ist.”).
When I reboot locally on the console via SSH login into nabu case works.
So something is different when the gitlab runner makes the restart or when I do it locally on the console.
I have the same problem right now and reported here: Cloud service not loading after recent update.
